Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-08-2009, 02:05 PM   #11
es88gt
Vehicle: 1988 Ford Mustang GT
will trick flow heads work on a 351? or be too small. Thinking of goint with a trick flow top end kit, as was doing a 331 or 347, but now looking into a 351 based motor.
es88gt is offline   Reply With Quote
Old 09-08-2009, 02:58 PM   #12
83fox50
1983 Ford Mustang
Quote:
thanks for the high jack...but anyway yes trickflow makes a head for a 351. look into the 205 cc heads.
__________________
Stang Newb!!!
83fox50 is offline   Reply With Quote
Old 09-09-2009, 12:07 AM   #13
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
hey noob...leave the noobs thread alone/ don't hi-jack it, create your own thread if you wish to know the answer or better yet don't be so lazy and use the search function, thank you and welcome
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-09-2009, 01:45 AM   #14
kuikcat
Vehicle: 91 ford mustang
i woul go with twister wedge if clearence was an issue.
kuikcat is offline   Reply With Quote
Old 09-09-2009, 11:51 PM   #15
83fox50
1983 Ford Mustang
aight i think im gonna try out the FAC heads from trickflow, and ill just have the machine shop fly cut the pistons and clean the block and put new bearings and rings in it while hes in there.
any ideas on the power it should make? other important info: mac longtubes and dumps, weiand stealth intake 650 cfm carb.
im hoping 400 at the wheels, but more realistically i think i will be around 365
__________________
Stang Newb!!!
Old 09-09-2009, 11:57 PM   #16
mjr46
mjr46's Avatar
Vehicle: 85 mustang
ditch the 650 for a 750 since it's a stroker
__________________
Old 09-10-2009, 10:18 AM   #17
83fox50
1983 Ford Mustang
someone help me out with this one then. for the fly cuts, does that do the other side of the valve or just enlarge the relief to accommodate a larger valve. do i really need to fly cut these for a FAC head? the hole saw in the pic is 2.125 inches.
__________________
Stang Newb!!!
Old 09-10-2009, 11:08 AM   #18
mjr46
mjr46's Avatar
Vehicle: 85 mustang
I can't remember if the FAC head is a inline valve head, if so then you shouldn't need to flycut
__________________
Old 09-10-2009, 11:13 AM   #19
mjr46
mjr46's Avatar
Vehicle: 85 mustang
hmmmm, just looked at the website.......looks like they are a twisted wedge design/ rotated intake, so you may have to flycut for twisted wedge fac heads ......if you wish not to do such go with the afr 185's
__________________
Old 09-29-2009, 07:38 PM   #20
83fox50
1983 Ford Mustang
ordered heads today, should be here soon. bought the TFS FAC 190's. im all giddy now.
anywho, i called trickflow just to talk to a tech and they said the mechanic just put them on a flat top piston engine and had absolutely no PTV clearance issues. he also said a TFS stage 2 cam should work no problem, and it would probably put me right at my goal.
pics coming soon.
__________________
Stang Newb!!!
185, 331, 51400010c01, afr, block, dss, end, ford, forums, heads, hp, kit, max, mustang, pistons, probe, short, tfs, top
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
