NEW TRACK TIMES!!! Half way respectable too!
Old 09-08-2009, 06:38 PM
AdderMk2
Banned
AdderMk2's Avatar
Default NEW TRACK TIMES!!! Half way respectable too!
So I took the car up for a rental day at the track. Ran some decent times. I still have to work on my launch however.
Im still running the Summit lower control arms, which will get sapped out soon for some UMI lift bars. I'm also going to be running Hoosier Quick-Time Pro tires on some 15's. These times were on my Nitto's with 35PSI (i forgot to deflate them a bit)
60' - 2.13 (boo!)
1/8 - 8.22
mph - 94
1/4 - 12.42
mph 113
with a better launch, drop my 60' to about a 1.6 or 1.7, i should see high 11's. I'm still having a problem with second gear in my 3550, its getting torn apart this winter and having some faceplating done.
AdderMk2 is offline
Old 09-08-2009, 06:42 PM
NoGo95GT
NoGo95GT's Avatar
SLOW AS ***** ADDER :P But seriously, great times, especially for that weenie 60ft. But, I would have expected your car to trap higher than 113, especially after that 94mph 1/8th.
NoGo95GT is offline
Old 09-08-2009, 06:46 PM
AdderMk2
Banned
AdderMk2's Avatar
im still running pig *** rich in the high RPM's. from ~4200-5000 the car sees low 11:1 AFR's.
I still have alot of tuning to do
AdderMk2 is offline
Old 09-08-2009, 06:50 PM
NoGo95GT
NoGo95GT's Avatar
Okay, I see now. I know when I ran a 2.2 60ft, I ran a 8.29 1/8th. Then a month later I somehow managed a 1.84 60ft(on balder than bald Nittos) which ended up being my crappy 7.57. So yeah, you should easily run a mid 11 second pass with a better 60ft. Nonetheless good times. Are you tuning it with a Tweecer?
NoGo95GT is offline
Old 09-08-2009, 06:54 PM
AdderMk2
Banned
AdderMk2's Avatar
quarterhorse
AdderMk2 is offline
Old 09-08-2009, 07:35 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
How much does your car weigh and which gears are you running?
TrimDrip is offline
Old 09-08-2009, 08:01 PM
AdderMk2
Banned
AdderMk2's Avatar
~3350 with me in it, and 3.73's
AdderMk2 is offline
Old 09-09-2009, 05:25 PM
tinman
tinman's Avatar
Those Hoosier tire will light that thing up. I think if car will hook you'll see some more MPH.......
tinman is offline
Old 09-09-2009, 05:51 PM
kweb288
kweb288's Avatar
ya gotta work on that 60'
But your getting there man! now lets get some vids!
kweb288 is offline
Old 09-09-2009, 05:54 PM
AdderMk2
Banned
AdderMk2's Avatar
im pretty sure my 1-2 shift is IN the 60'... because my car comes off the line pretty good. Im still having issues with my clutch... I think there is something screwed up inside the bellhousing, when I step on the clutch, I get a "click" noise that I have tracked to the clutch fork.. so IDK what the deal is with that. Ill have to pull the trans and figure it out..
AdderMk2 is offline
Quick Reply: NEW TRACK TIMES!!! Half way respectable too!
