Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-08-2009, 10:39 PM   #1
F150 StrokerCobra
Default Timing and Carb settings... holley 650
what does the base timing has to be???
i know that i need a total of 34-36 timing at 3500 rpm of advance but what timing to set at idle??
holley 4150 double pumper mechanical advance
and any tricks to set the idle air/fuel mixture without a vacuum guage ??
__________________
--==Jurgen==--
Under Construction: 1989 F150 reg cab longbed
5.0 HO, Comp custom cam 0.18/0.24 @0.50 0.513Lift , Flowtech LT's, hooker aero chambers, GT40 heads, Edelbrock Air Gap Performer intake, Holley 650dp Carb,
F150 StrokerCobra is offline   Reply With Quote
Old 09-08-2009, 11:21 PM   #2
67mustang302
Vehicle: 67 Mustang Coupe
Around 14
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 09-09-2009, 12:01 AM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
base can vary, expecially with performance cams, where ever drivibility and idle quality are the best. and as for having total in at 3500, that's not in stone either, for my set up total was recommended all in by 2300, so advance rate can vary based on your combo, you have to be the one to feel it out and see where it is most responsive, then again your working with a 302 set up and me a 347, generally if you have only idle air bleeds on the primaries your task is alot easier to balance idle quality then a 4 corner set up is, with just two start with them 1.5 turns out from the lightly seated/closed position, don't wrench them down...lightly until they stop then back out 1.5 turn, from there turn both with car idling maybe 1/8 turn out or in and see if idle quality improves, if it does you'll know your going the right way.....but heck a vac gauge is cheap..good luck
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 09-09-2009, 01:32 PM   #4
Jfsram
Vehicle: 93 Mustang LX
Some distributors will not allow for the total and idle timing settings. Let's call it spread.
If you are aiming for 14 initial and 34 total. Lucky if you dist has a 20 spread. If not you will have one of your settings too high or too low.
Easiest solution, since it's not my money. Is to buy an aftermarket dist with adjustable spread. Or modify the advance mechanism.
__________________
65 Belevedere
69 Super Bee
87 Ram
93 Mustang
00 Park Avenue
http://www.cardomain.com/ride/754650
Jfsram is offline   Reply With Quote
4150, 50, 650, air, carb, fuel, holley, mixture, mustang, set, setting, settings, time, timing, tuning
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
