Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-14-2009, 11:48 AM   #1
projectresto83
projectresto83's Avatar
Vehicle: 83 GLX, 93 LX, 98 sixer
Default Battery Relocation Ground Length
For those who have done the battery relocation how long was your main ground wire?? I'm working on getting free parts together for stuff like that from vehicles over here that I work on. I have a 3/0 ground wire already with ens that is about 2 1/2 -3 feet long set to the side that I figured I would use.
__________________
Off building sand castles in the middle east
projectresto83 is offline   Reply With Quote
Old 09-14-2009, 12:39 PM   #2
Milton
Vehicle: 1995 mustang gt
that should be plenty long enough, all it needs to do is go to a good clean (bare) spot on the chassis (frame would be ideal). The ground on vehicle isn't really a ground its a neutral or negative wire, that uses the vehicle itself to complete the circuit. take an amp for example you wire the + straight to the batt. (through a fuse obviously) then "ground" it to the trunk, the electricity then goes through the chassis and up through the "ground" in the front of the car to the batt. a trunk mounted battery is wired basically the exact same as a trunk mounted amp except for where your + goes to
__________________
Milton is offline   Reply With Quote
Old 09-14-2009, 01:35 PM   #3
projectresto83
Quote:
Same thing. I know it would be depending on how I routed it, I was just curious on others lengths.
__________________
Old 09-14-2009, 01:45 PM   #4
Milton
its more of a bonding wire as it doesn't actually go to ground but yes your right. and that explanation was long and completely off topic, i had just gotten home from school... if have 2-3 feet what should be way more then enough as all you really have to do is go the hight of the battery say one foot, then through the floor boards so you have 1.5-2 feet to find a good connection.
__________________
Old 09-14-2009, 02:07 PM   #5
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
my main ground is 1/0 x 3feet.
i have it through the floor and attached at the frame, right at about where teh quad shock use to mount.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 09-14-2009, 02:32 PM   #6
projectresto83
Ummmmmm...... yea it does......the negative side of the battery to the body..... anyway thanks for the input and get back to school. The grounding wire from my motor to my chassis is my "bonding wire".
__________________
Old 09-14-2009, 03:15 PM   #7
FivePointOhh
also, not sure if you wanting to know, but power wire is 15foot approx. thats all in needed at least.
__________________
Old 09-14-2009, 03:39 PM   #8
projectresto83
Thanks. I might have to chop up a set of slave cables for that . Those are just a big set of jumper cables for military vehicles. Prolly at least 4/0 or 5/0.....I think thats big enough lol.
__________________
Old 09-14-2009, 06:44 PM   #9
luckythirteen13
luckythirteen13's Avatar
i run my ground to the hatch and then to the engine block. the one to the block is really long, good 15ft if i had to guess
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 09-14-2009, 11:42 PM   #10
projectresto83
^ I see what your getting at lucky. I am going to try and centralize all my grounds through out the car as much as possible.
Did you guys keep the solenoid in the front or did you move it to the rear? I have seen both.
__________________
50, batery, battery, car, classic, ground, grounding, importance, mounted, mustang, negative, relocated, relocation, trunk, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
