Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-15-2009, 01:12 AM   #1
Styg
Vehicle: 1992 LX 5.0
Default Is there a speed limited on the 5.0s
I tried searching on the web, but I can't get the clear answer for this. Has there been a limited on the 5.0 mustangs. Mine is a 1992 auto and it fails miserably at 120mph. It gets up there alright, but at 120mph it just hits the wall. I don't know why, at one point it even downshifted to D while I was sitting at 120mph. I was at 5000RPM in D and still not going anywhere.
So back to the question, was there any type of the limiter on the 1992 auto 5.0 ?
Thanks.
Styg is offline   Reply With Quote
Old 09-15-2009, 02:41 AM   #2
luckythirteen13
luckythirteen13's Avatar
you dont have enough hp to pass 120mph. ive been 130mph in mine and i know others have gone faster. there is a rpm limiter tho.
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 09-15-2009, 02:42 AM   #3
86 5.0L
86 5.0L's Avatar
Vehicle: '86 Mustang GT
http://en.wikipedia.org/wiki/Aerodynamics
no, no limiter
__________________
Car: 1986 Mustang GT Hatchback || 5.0L H.O. || Borg-Warner T5 || 148,000 Miles || 25mpg
Mods: Bfg Traction T/As || Front sway bar || K&N/silencer removed || Hood pins
Times: faster then a speeding Prius
86 5.0L is offline   Reply With Quote
Old 09-15-2009, 02:44 AM   #4
86 5.0L
86 5.0L's Avatar
Quote:
unless you can hit 225+mph I wouldnt worry about it
__________________
Old 09-15-2009, 05:58 AM   #5
302army187
1989 Ford Mustang
302army187's Avatar
Vehicle: 89 mustang lx 'vert
I wouldent recommend trying to top out over drive with a AOD transmission. You will burn it up.
if you MUST hit 120+mph, take 3th "drive" as far as it will take you to be easyer on the trans
__________________
302; Cobra T5, 4.10's, ported E7's, Typhoon intake, full bolton's, full exhaust, NX 100-150wet shot
UPR upper/lower control arms, MM full length subframes, Strange Engineering 10way Shocks & Struts
Mods on the way: Ported&O-Ringed Trick Flow heads, TF stage 2 cam, a/c removal, battery relocation
Thanks for the sig' Xeno!
302army187 is offline   Reply With Quote
Old 09-15-2009, 06:01 AM   #6
87slutstang
87slutstang's Avatar
Vehicle: 1987 ford mustang
I thought there wars a limiter too when I got my car. No matter what the car wouldn't pull past a certian RPM. Put a BBK SSI intake on there and flew right past it.
__________________
restrictor plate removed
87slutstang is offline   Reply With Quote
Old 09-15-2009, 10:06 AM   #7
projectresto83
projectresto83's Avatar
Vehicle: 83 GLX, 93 LX, 98 sixer
5000-5500 is usually the limit on the rpm range in stock mode.
__________________
Off building sand castles in the middle east
projectresto83 is offline   Reply With Quote
Old 09-15-2009, 06:54 PM   #8
Styg
Thanks for the responses guys. This is my first 5.0 so I am not knowledgeable in the AOD workings or the top speed. 120mph just seemed way too low for the car. You probably are right regarding it running out of HP, the car is 100% factory stock so in the best case scenario I have 170WHP.
Old 09-15-2009, 08:08 PM   #9
Shelty
1991 Ford Mustang
Shelty's Avatar
Vehicle: '91 5.0 LX 'vert
Send a message via AIM to Shelty
Ive hit 130+ in my car, but its a 5 speed... usually around 120-140 is where the foxbody cant go any faster... aerodynamics take effect there
__________________
'91 5.0 5-speed
full O/R exhaust, Ram Air Intake,pullies, full length SF connectors, CF DF clutch, tri-ax, aluminum drive shaft, slotted rotors, strange 10 ways, exterior mods/ some interior billet bling
soon...more suspension work i.e. control arms, springs, ball joints, bushings etc in due time (Imma broke college lad)
Shelty is online now   Reply With Quote
Old 09-15-2009, 08:33 PM   #10
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
you need more power
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
1989, 50, body, fox, gt, high, hit, light, lights, limiter, mustang, overdrive, pursuit, rev, speed
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
