Head
Old 09-25-2009, 02:46 PM
Notch 8022
Notch 8022's Avatar
Default Head
What type of heads could I put on a 87 mustang 5.0 H.O. motor without beaking the bank? I have a stock mustang with BBK shortie headers, at least I was told that.
Notch 8022 is offline
Old 09-25-2009, 03:05 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
what's your idea of not breaking the bank???
mjr46 is offline
Old 09-28-2009, 01:51 PM
Notch 8022
Notch 8022's Avatar
More that $700 bucks.
Old 09-28-2009, 01:53 PM
Notch 8022
Notch 8022's Avatar
From what I can see a set of heads run $1500. You might as well go with a supercharger kit...
Old 09-28-2009, 01:57 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
I picked up a bare set of new Holley heads on ebay for 420. After machining you should be around 700. Holley still has some on ebay if you want to go that route.
Tristatecylinderhead.com has some aluminum reman heads for about that too.
Otherwise used heads would be the way to go.
TrimDrip is offline
Old 09-28-2009, 02:00 PM
NoGo95GT
NoGo95GT's Avatar
To the OP, you will also need to buy new gaskets, bolts,possible pushrods, etc. Everything can add up quickly.
NoGo95GT is offline
Old 09-28-2009, 02:05 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
You would come out better doing the heads first. It would be like putting a supercharger on the car. On the other hand, it would keep you from having to chop the car up as much.
There is a little more to bolting on a supercharger unless you go with the fmu.
TrimDrip is offline
Old 09-28-2009, 04:32 PM
Feller
Feller's Avatar
This is an area where you don't really want to go the cheap route. I'd say save up for a whole kit so you don't have to search all over to get everything you need. Then again you could find someone local selling gt-40s and be satisfied with that.
Feller is offline
Old 09-29-2009, 09:24 AM
Notch 8022
Notch 8022's Avatar
thanks for all your help. Would GT 40 heads give a significant amount of power gain? Would the bbk shortie headers work with these heads? I am concerned with sparkplug removal...
GimpyHSHS
19
12-19-2023 01:12 PM
mustangheaven
01-03-2016 11:20 AM
kevsgt
10-09-2015 10:12 PM
mustangheaven
10-07-2015 10:23 AM
Drastang
09-30-2015 03:48 AM
Quick Reply: Head
