The spedo is run by a gear on the side of the transmission. http://www.latemodelrestoration.com/...eed-Correction. You pull the gear out put in the new one, you might have to take your old one out then count the teeth inside then find out the correct ratio you need for it to work. Im unsure of the correct number of teeth gear you need.
