I'm going to be building a mid-high 10's NA car. I'm building up and pricing out my parts list right now and could use some help. I'm going with a Dart Aluminum block, no sure if i want to go with the 302 or the 351 though. Any help on Cams, heads, pistons and the like would be a big help.
the stock 302 is high miles and really worn. I wouldn't want to put the money into it. I wanted to buy a good block designed for a lot of hp/tq and something i could build and not have to worry too much about power limitations
Then I could tell you that if you are using an iron 351W block in a FOX body Mustang you end up with lots more wieght on the front end than you would have with a 5.0 block.....
