Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-15-2009, 02:28 PM   #1
busheymotorsports
busheymotorsports's Avatar
Vehicle: 1988 mustang gt
Default HELP!!! has spark,getting fuel, no start??
1988 Mustang GT...the car is getting spark, is getting fuel(43lbs), but the injectors are not pulsing. Also, I can hear the fuel pump turn on and stay on, it doesn't shut off when it has built pressure. Someone suggested it might be the TFI module which I repalced today, no dice. Any suggestions?
busheymotorsports is offline   Reply With Quote
Old 10-15-2009, 02:35 PM   #2
ksranger
Vehicle: 1988, Ford, Mustang
Checked for codes?
__________________
"Don't you worry we'll all float on"
ksranger is offline   Reply With Quote
Old 10-15-2009, 02:43 PM   #3
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
injector pulse is directly controlled by the PIP module inside the distributor, which then relays the pulse through the TFI.
Given that you've replaced the TFI, no injector pulse now = bad PIP or bad computer
ACDELCO Part # F1930
Motorcraft Part # DU30C
Crosses to Autozone Duralast part # F122, $19.99
__________________
mattdel is offline   Reply With Quote
Old 10-15-2009, 03:11 PM   #4
bigduderedgt
Vehicle: 1993 mustang gt
is it a 88 motor? and with harness from same year? 88 harness will not work on diff year motor unless you change harness to match motor year. i went through same problem few years back with a 88LX 5.0, ended going carb and rewired striped down harness.
bigduderedgt is offline   Reply With Quote
1988, 2000, 2005, 93, efi, ford, fuel, gt, injector, module, mustang, pulse, start, tfi, wont
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
