Quote:
Originally Posted by PRO50SC
First you need to determine why it's not starting. Is it b/c there is no spark, or no fuel? What have you checked?
No fuel, it was sort of sputtering at first, then it was just turning over, also, no pump sound, and 542 code. Sorry I didn't make it clear.
After going through a lot of wires I traced it down aftermarket immobilizer (secret switch) problem, now the car is running again.
Quote:
Originally Posted by mjr46
Thank you, this is a very useful link. I will bookmark it. Since I don't repair cars every day I tend to get sidetracked by some stupid, unrelated symptoms most of the time.
Still, I will have to check that 542 code though, because it seems it's persistent even the car runs just fine. It's quite possible that guys who were adding the immobilizers and alarms, did something wrong. I will reset the codes and if they'll come back I'll have to do some wire tracing.
By the way, do you know where the fuel pump relay is on a '95 GT?
