Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 12:58 PM   #11
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Send a message via AIM to mattdel
Quote:
Originally Posted by mjr46 View Post
once the distributor is in the shaft won't fall out, that just keeps it from coming out when pulling the dizzy up , incase it desides to stay lodged in the dizzy shaft
that happened to me a couple months ago changing my neighbors 67 over to electronic ignition. Needless to say I was not pleased the next couple hours.
__________________
mattdel is offline   Reply With Quote
Old 10-20-2009, 01:33 PM   #12
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
hypothetically speaking. if it popped up out of its spot. do you think the dizzy is getting wedged in by the shaft...so thats why it wont drop further than just getting over the tip of the pump driveshaft?
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 10-20-2009, 01:48 PM   #13
mattdel
mattdel's Avatar
Vehicle: 1986 LX
Quote:
the clip is made in a way that allows it to be pushed down, but not supposed to be able to come up. plus if the shaft wasn't seated in the pump, you'd know it, cuz it would probably be in your pan.
__________________
Old 10-20-2009, 08:55 PM   #14
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
if you are using the same parts that were previously installed then the issue is solely needing to line up the shaft with the hex on the dizzy, sometimes it takes me numerous attempts when it gets out of align
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-21-2009, 01:51 AM   #15
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
try adding a little black silicone to the end of the shaft and installing it in the distributor. Let it sit a few minutes so it will hold, then install the shaft using the distributor. The balancer should be at 0 degrees.
TrimDrip is offline   Reply With Quote
Old 10-22-2009, 09:21 PM   #16
94StinkinLincoln
94StinkinLincoln's Avatar
Vehicle: 1995 mustang gt
Send a message via Yahoo to 94StinkinLincoln
TDC on the COMPRESSION stroke on #1 cylinder.
if you dont have it on compression: it probably will not start and you will smell fuel in the exhaust.
been there done that, same with the shaft... took the advise of taking the retainer clip off... the BEST thing to do is drop the pan and the oil pump and put a shaft in with a clip and put the oil pump back on. If you drop the shaft, you will be doing just that.
I used wheel bearing grease to create a suction on the shaft in the dizzy, silicone should work too like someone mentioned. take your time.
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
94StinkinLincoln is offline   Reply With Quote
Old 10-23-2009, 03:10 AM   #17
nacanitihs
Vehicle: 1989, Mustang GT
did u try rotating the rotor my hand while pushing the dizzy down? its a helical gear
__________________
SVO GT40x Aluminum Heads, FRPP F303 Cam, GT40P Intake, 3.73s, Full Exhaust and Suspension
http://i56.photobucket.com/albums/g1...ynosheet-1.jpg
275rwhp and 300ftlbs
nacanitihs is offline   Reply With Quote
Old 10-23-2009, 09:47 AM   #18
FivePointOhh
^you'ze not listen'n. its doesnt even make it as far as the gears touching. it just barely gets the base of the dizzy of the tip of the oill pump drive shaft. somethign is holding it up.
__________________
Old 10-23-2009, 11:55 AM   #19
nacanitihs
lol oh sry there was a lot to read so i skimmed my way through
__________________
Old 10-23-2009, 07:36 PM   #20
5.0stanger
5.0stanger's Avatar
Did you ever get it to go in? did you pull the shaft and try it? Will the base of the dizzy even start going in?
__________________
-Kyle
5.0stanger is offline   Reply With Quote
89, forum, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
