Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-19-2009, 02:05 PM   #1
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
Default dizzy stabbing issues
ok i feel really stupid for posting this. i've done this a 100 times but for some reason i cant get my dizzy to drop in.
i've had the oil pump rod out, made sure it fits into the dizzy, thats not the problem. the dizzy will drop just far enough to slip over the tapered tip of the pump rod. but i still have a good inch or so before the dizzy will seat in the hole. it doesnt even contact the cam, i can completely spin the rotor. i've spun the engine manually, spun the rotor, slammed the fackin dizzy down. this thing has me in a fit of rage cause it will not drop. i've inspected the hole, there is nothing in the way. i have no idea what the fack is going on. why wont my dizzy drop?
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 10-19-2009, 03:58 PM   #2
mustangsneverdie
1985 Ford Mustang
mustangsneverdie's Avatar
Vehicle: 1991 mustang
take the driveshaft out and see if the dizzy will drop in then.If not you may have a bur or 2 stopping it from going any further
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
mustangsneverdie is offline   Reply With Quote
Old 10-19-2009, 04:03 PM   #3
FivePointOhh
yea i didnt try that. i will after work. hopefully its that simply. for some reason i dont think it will be though
__________________
Old 10-19-2009, 08:30 PM   #4
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
you can pull the shaft out?? you shouldn't be able to.....there is a little collar on there to keep it from pulling up, once I had that collar slid up to far and wouldn't allow dizzy to drop down far enough
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-19-2009, 08:34 PM   #5
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
Sometimes after dropping it in, you have to bump the engine for it to drop the rest of the way down.
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 10-19-2009, 08:36 PM   #6
motorman524
MF Informant
2008 Ford Focus
My Garage
motorman524's Avatar
Vehicle: 1987 Ford Mustang
That collar also keeps the shaft from coming out of the oil pump. If it comes out, it's bye bye oil pressure and whatever else it does damage to.
__________________
1987 ex-4banger
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax Intake-DONE!!
motorman524 is offline   Reply With Quote
Old 10-20-2009, 11:22 AM   #7
FivePointOhh
there was no collar. my neighbor told me about it too. there wasnt one in there when i had the motor apart the first time, this last time, or this time around. i have no idea what that collar is supposed to even look like. in the history of this motor its never had one.
__________________
Old 10-20-2009, 11:23 AM   #8
FivePointOhh
Quote:
yes i can pull it all the way out.
__________________
Old 10-20-2009, 11:33 AM   #9
FivePointOhh
ohhhhhhhhhh i see now. went to summit's website. found a picture of one. yea i've never had that thing on my driveshaft for the oil pump.
__________________
Old 10-20-2009, 12:47 PM   #10
mjr46
mjr46's Avatar
Vehicle: 85 mustang
once the distributor is in the shaft won't fall out, that just keeps it from coming out when pulling the dizzy up , incase it desides to stay lodged in the dizzy shaft
__________________
89, forum, mustang
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
