Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-25-2009, 06:49 PM   #11
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
Quote:
Originally Posted by 88windsor View Post
the motor spins but wont CRANK(no combustion)there is both fuel and spark. the starter sounds fine and fast seems like it throws it self way out of time but it IS in time.
I give up! Lack of Terminology owns you
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 10-25-2009, 07:40 PM   #12
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
...you seriously need to learn automotive terminology, correct terminology for your issue at hand is CRANKS BUT WON'T START!!!!!!!
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is online now   Reply With Quote
Old 10-26-2009, 07:46 PM   #13
notchx2
Vehicle: 1989, Ford, Mustang
I had the exact problem with my 89. Turned out to be fuel pump. Just because there is some fuel pressure does not mean there is enough fuel pressure. To test fuel pressure, connect a gauge to the schraeder valve on the fuel rail. I believe it needs to be approx 40psi. An easier indication that this is the problem is to turn the key to on (not start, not cranking the engine), and listen for the fuel pump. If you don't hear it run for a second or two, it is not pressurizing, and may well be you're problem.
notchx2 is offline   Reply With Quote
Old 10-26-2009, 09:34 PM   #14
lxman1
Vehicle: 1988 Ford LX hatch
I agree Notch. You need to hook up a fuel pressure gauge to see how much pressure is actually there when it won't start.
Also, a new TFI module does not always guarantee a good module.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
1985, 1991, 46l, 50, 89, crank, ford, hot, module, mustang, problem, problems, slow, start, starting, tfi
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
