Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-19-2009, 05:55 PM   #1
88windsor
1988 Ford Mustang
88windsor's Avatar
Vehicle: 1988 ford mustang
Default starting problem when hot, please help!!!!
I have a 89 mustang 5.0L it will start and run fine but when it reaches operating and i shut it off the engine will turn over but will not start. please help,Thanks
88windsor is offline   Reply With Quote
Old 10-19-2009, 07:09 PM   #2
mustangsneverdie
1985 Ford Mustang
mustangsneverdie's Avatar
Vehicle: 1991 mustang
could be your coil, wires, tfi module, or dizzy but most likely tfi module
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
mustangsneverdie is offline   Reply With Quote
Old 10-24-2009, 04:34 PM   #3
88windsor
1988 Ford Mustang
88windsor's Avatar
Question map sensor?
Could a broken map sensor cause it not to start when hot? Because recently i changed the heads and before that it ran fine and the only thing different are the heads and the map sensor got wedged under the upper intake and cracked the map sensor. I already have a new tfi module ,wires,coil,and cap so im stumped. any ideas would be great. Thanks
Old 10-24-2009, 04:44 PM   #4
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
Vehicle: 92 Notch Procharged!
Send a message via AIM to PRO50SC
You need to find out if it's losing spark or fuel
__________________
92 LX NOTCH PROCHARGED
DRIVE IT LIKE YOU STOLE IT!!!
ROTM 08/06
11.761 run from 4/4/09
See my Movie
Wheels up!!
PRO50SC is offline   Reply With Quote
Old 10-24-2009, 08:12 PM   #5
88windsor
1988 Ford Mustang
88windsor's Avatar
it has both fuel and spark and it still wont crank
Old 10-24-2009, 08:21 PM   #6
PRO50SC
The Rogue Mod
1992 Ford Mustang
PRO50SC's Avatar
OK, you've just contradicted yourself. So which is it.
__________________
ROTM 08/06
See my Movie
Wheels up!!
Old 10-24-2009, 10:45 PM   #7
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
^^^^^lol noobs, I always love explaining the difference between cranks but won't start vs won't crank so it won't start..lol
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-24-2009, 10:51 PM   #8
sick89
Vehicle: 89 Ford Mustang LX
Does it not start because it seems like the battery is going dead or does it crank ok just wont start? Mine had a bad starter/soleniod which made the car seem like it had a dead battery when it got hot if thats the problem your having....
sick89 is offline   Reply With Quote
Old 10-24-2009, 11:08 PM   #9
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
so the car cranks slow?
sounds like starter heat soak
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is online now   Reply With Quote
Old 10-25-2009, 06:44 PM   #10
88windsor
1988 Ford Mustang
88windsor's Avatar
the motor spins but wont CRANK(no combustion)there is both fuel and spark. the starter sounds fine and fast seems like it throws it self way out of time but it IS in time.
1985, 1991, 46l, 50, 89, crank, ford, hot, module, mustang, problem, problems, slow, start, starting, tfi
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
