Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-21-2009, 10:47 PM   #1
F150 StrokerCobra
Default Holley Carb high idle!!!
no vacuum leak anywhere double and tripple cheked it!
cold start it idles around 650 where i want it to be,,, get at opp temp and start driving around it idles around 1000 - 900 i go at the carb and push the throttle lever down ant the idles drops around 600 ish why is this? is there something stuck?? i cant seem to find anything stuck or damaged!! 900 idle is boring!! i want a 650 idle so the cam can sing
and yes i do have a return spring on it but it doesnt help! i also put 2 return springs but nothing!!
and the idle screw is full out cant go any further
this is the holley im using its from summit rebuild ones
__________________
--==Jurgen==--
Under Construction: 1989 F150 reg cab longbed
5.0 HO, Comp custom cam 0.18/0.24 @0.50 0.513Lift , Flowtech LT's, hooker aero chambers, GT40 heads, Edelbrock Air Gap Performer intake, Holley 650dp Carb,
F150 StrokerCobra is offline   Reply With Quote
Old 10-22-2009, 03:16 PM   #2
67mustang302
Vehicle: 67 Mustang Coupe
Check the choke side of the carb, sometimes if the high idle isn't set right the screw can hang up on the cam and prevent the throttle from fully closing. Also check for binding in the throttle linkage.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 10-22-2009, 07:29 PM   #3
mustangsneverdie
1985 Ford Mustang
mustangsneverdie's Avatar
Vehicle: 1991 mustang
my car always seemed to do it to and I would do a quick slap on the accelerator and it would go back to normal
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
mustangsneverdie is online now   Reply With Quote
Old 10-22-2009, 11:21 PM   #4
F150 StrokerCobra
Quote:
allright ill chek that tomorrow
Quote:
yupp i do that 2 but it stays at 900
__________________
--==Jurgen==--
Old 10-25-2009, 12:36 PM   #5
lxman1
Vehicle: 1988 Ford LX hatch
Might look at the pitch on the secondary blades, they may to slightly too far open, causing more airflow and higher idle when warm.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
Old 10-25-2009, 11:10 PM   #6
F150 StrokerCobra
Quote:
how to chek this???
__________________
--==Jurgen==--
289, cam, carb, carburetor, cold, doesent, edelbrock, high, holley, idle, lift, linkage, return, setting, spring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
