Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-23-2009, 12:04 PM   #1
SEEW21
Vehicle: 95 ford mustang
Default 302 engine 2 valve or 4 valve?
Is the 1995 5.0 engine a 2 valve or 4 valve engine?
Thanks
__________________
1995 Mustang GT- BBK Shorty Headers, Flowmasters, Off Road X-Pipe, Aluminum Driveshaft, 3.73 Gears, Underdrive Pulleys.
SEEW21 is offline   Reply With Quote
Old 10-23-2009, 12:09 PM   #2
motorman524
MF Informant
2008 Ford Focus
My Garage
motorman524's Avatar
Vehicle: 1987 Ford Mustang
it is 2v. the 5.0's in this section are pushrod. There are 4v OHC 5.0's tho
__________________
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax Intake-DONE!!
motorman524 is offline   Reply With Quote
Old 10-23-2009, 12:13 PM   #3
motorman524
MF Informant
2008 Ford Focus
My Garage
here is an ohc 5.0
here is a pushrod 5.0(mine)
__________________
Winter Project:
Steeda Control Arms
Old 10-23-2009, 01:05 PM   #4
SEEW21
ok thanks guys. Another quick question: So the Cobra is a 32 valve, is that far superior then to the 2 valve engine? Is that getting a lot more air to the cyclinders and improving the performance a lot?
__________________
Old 10-23-2009, 01:22 PM   #5
motorman524
MF Informant
2008 Ford Focus
My Garage
96 up Cobras come with a 4.6 32 valve. I wouldn't say that it is far superior, just good engineering. Yes, 4v heads do flow better.
__________________
Winter Project:
Steeda Control Arms
Old 10-23-2009, 02:55 PM   #6
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
Originally Posted by motorman524 View Post
here is an ohc 5.0
FWIW that 5.0 Cammer is still a 4.6l mod motor, its only has 5.0l of displacment (read: stroker)
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 10-23-2009, 02:56 PM   #7
Styg
Vehicle: 1992 LX 5.0
Is that 5.0 a coyote engine that is going into the 2010 mustang ?
Styg is offline   Reply With Quote
Old 10-23-2009, 03:27 PM   #8
kweb288
1992 Ford Mustang
kweb288's Avatar
Vehicle: 1992, hatch
4v 04 cobra engines are superior in my opinion...
__________________
Currently putting an 04 cobra engine in my fox http://www.mymustangproject1.webs.com
kweb288 is offline   Reply With Quote
Old 10-23-2009, 08:22 PM   #9
FoxGT
Vehicle: unicycle
Send a message via AIM to FoxGT
I think all of the 4v 4.6's are superior, performance wise. Not so much in the cheaper/easy to work on field though imo.
__________________
If you have to ask what it takes to get to 500 HP, you don't have what it takes to get there.
'89 Mustang GT
'86 Mustang vert
'84 TT 351w notch
'89 Turbo Ranger
'96 Musta
FoxGT is offline   Reply With Quote
Old 10-24-2009, 02:14 AM   #10
lxman1
Vehicle: 1988 Ford LX hatch
Much more efficient for sure.
Even the 3V engines are very efficient.
The 93 Cobra 5.0 has 235hp. A new 3V 4.6L has 315hp.
Add 5lb of boost to a 3V 4.6 and gain a lt more power than putting 10psi on a stock 5.0.
2V = 2 valves per cylinder
3V = 3 "" ""
4V = 4 "" ""
The 5.0 has the camshaft in the block, the 4.6L engines have the cams in the heads.
2v and 3V 4.6 are SOHC (one cam per head) and the 4V is a DOHC (2 cams per head).
I hope this helps clarify the situation SEEW21.
__________________
1988 5.0 T5 LX HB
Oxford white
Saddlebeige interior.
Exploder intake
BBK 70MM TB
Cobra 70MM MAF
E303 cam
3.8L Taurus E-fan
lxman1 is offline   Reply With Quote
1995, 302, 4v, craigslist, engine, ford, forums, head, heads, make, mustang, parts, valve, valves, vehicles, versus, work
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
