where should i run my positive trunk battery wire?
i just got my battery relocation kit from ebay for a mere $70. where do people normally run the postive wire throughout the car? do people do it inside the cab or under the chassis? any help is appreciated.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
If I remember right NHRA rules says it is supposed to be on the outside of the car so they probably run it down the frame rail but there are probably only a few who really do that. You can run it right down the side of the car and out the firewall somewhere, most likely drilling your own hole.
What size wires did that kit give your? What kind of battery mount?
__________________ Off building sand castles in the middle east
i ran mine inside and the car and iirc, i read the 2009 nhra rules(i think they were the official rules) there is no requirement of where you can/can't run your positive battery wire.
__________________
I <3 my '89 LX 5.0 + MustangForums.com
Probably the easy/best way to do it is inside the cabin. If you are planning on NHRA racing the car, hope you got a switch kit to go withe the relocation stuff.......
__________________
GOOD,FAST, CHEAP-----------YOU CAN ONLY GET 2 OUT OF 3!!!!!!!!!!!!!!!!
There are many pros and cons to each but if you are all concerned. You should consider moving the solenoid to the back, with the battery. So your Positive wire is dead until cranking.
__________________
65 Belevedere
69 Super Bee
87 Ram
93 Mustang
00 Park Avenue
I ran mine through the hole in spare tire area then down the subframe and then up through the top of my kmember n to the solenoid
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
