Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-28-2009, 06:55 PM   #1
grod297
1967 Ford Mustang
Vehicle: 1989 Mustang 5.0
Default Tuned 331 BBk Vs Systemax here are the numbers
Okay so in answer to where has the torque gone on a built 331.
The bbk intake outperforms the systemax 2 in torque from 2900 RPM until 3200 RPM with the bbk producing 273 ft-lbs at 2900 vs the systemax producing 268 ft-lbs. At 3300 rpm the both produce 295 ft-lbs but that is where the competition ends. from that point on the systemax 2 climbs from 300 ft-lbs at 3400 RPM to a peak torque of 335 ft-lbs at 4400 RPM.
Max horse power from the BBK - RWHP - 293 at 5500 RPM
Max Horse power from Systemax 2 - RWHP 327 at 5800 RPM at 5500 RPM horse power was 324.
Well on the same engine heads ect. a 34 hp improvement just from changing the intake. and 9 ft-lbs improvment in torque.
The real question is will a 347 built similarly produce 400 ft-lbs at any rpm?
Any and all meaningful comments are welcome
G
grod297 is offline   Reply With Quote
Old 10-28-2009, 07:08 PM   #2
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
and to answer your question , I believe your lack of power output for the 331 lies in cam choice and heads......what heads and cam and exhaust do you have??? I have a 306 with a well put together combo putting out close to that
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 10-29-2009, 02:08 AM   #3
fs308
1995 Ford Mustang
My Garage
fs308's Avatar
Vehicle: 87 piece of sh!t
why are your numbers so LOW?? thats a lot of money spent for only 327 rwhp
__________________
Project:POS
fs308 is offline   Reply With Quote
Old 10-29-2009, 09:23 AM   #4
FivePointOhh
FivePointOhh's Avatar
Vehicle: 1989 Ford Mustang
Quote:
plus juan
__________________
I <3 my '89 LX 5.0 + MustangForums.com
FivePointOhh is offline   Reply With Quote
Old 10-30-2009, 10:43 PM   #5
grod297
1967 Ford Mustang
Hell if I know but those are the numbers. Maybe if I click my heels and wish hard enough they will get better. Or maybe I need a better Cam and spring combo.
The car feels better than it did stock and pulls better longer; but I thought the same thing when I got the report. The problem is that I do not want a rough idle cam .. I prefer very smooth and I do not know if you can get that and power with a push rod motor N/A.
At any rate thanks for the observation (you are right it is a lot of money for low numbers
Old 10-30-2009, 11:18 PM   #6
mjr46
mjr46's Avatar
Vehicle: 85 mustang
you can have a cam that'll perform and give a good idle, prob is OTS cams don't give you the best of both worlds, gotta go custom!! how does .550+ lift and under 220 on the duration for a good but noticable idle sound??? I'll have a sound clip tomorrow of such in my 89 vert thread.......www.flowtechinduction.com or www.camshaftinnovations.com can give you the best of both worlds, I use FTI and have 2 such custom cams in use........couldn't be happier.........what is the entire combo?? h/c/i??
__________________
Old 10-31-2009, 01:12 AM   #7
94StinkinLincoln
94StinkinLincoln's Avatar
Vehicle: 1995 mustang gt
Send a message via Yahoo to 94StinkinLincoln
i can not give an acct for FTI, but i have done business with CI and recomend them.
__________________
95gt, 331, canfield 195's, canfield efi intake; efi spyder elbow, ci cam, 90mm accufab TB, 1 3/4 accufab LT's, 3in accufab h pipe, 3in magnapacks, 4.30's, solid bushing rear upper/lower team z suspension, team z tubular k member and A arms, front coil overs with strange 10 way all the way around. currently aode; going to tko600.
For Sale:
aode,clutches,modified VB,3500 stall,28oz or stock flexplate, any thing needed for swap.
$1600 for trans, converter, and flex plate.
94StinkinLincoln is offline   Reply With Quote
Old 10-31-2009, 12:22 PM   #8
grod297
1967 Ford Mustang
Quote:
Heads afr 185
Cam -- Comp cam 35-518 -8 XR 274 Hyd Rollers
Intake Holley sytemax 2
Thanks
G
Old 10-31-2009, 12:34 PM   #9
ctgreddy
Vehicle: '95 gt 347
I reccomend a custom from CI. I've got one of their cams with .6/.592 lift and a 114 lsa and she idles nice. not much of a lope at all, just barely more than stock. and my car made better numbers than that when it was untuned. however youre going to see very minimal gains over that if you switch to a 347 bottom end. I think what you need is a better cam.
also is this with an auto? if so that would help explain a lot.
__________________
'95 Mustang GT- 347. Canfield 195's. Holley systemax. CI custom cam. 31 spline 8.8 w/ 4.10's. TKO 3550.
12.8@112; 339/365 with a bad tune.
ctgreddy is offline   Reply With Quote
Old 10-31-2009, 12:58 PM   #10
grod297
1967 Ford Mustang
No this is a manual trans ( sad huh) The more I think about it a built 331 with 9:6:1 compression and forged internals -- A lot of money put in the wrong place I fear. Maybe I will put on a vortech and see what happens -problem is its a stock block and with the compression at 9:6:1 I wonder how musch boost I could run before the engine becomes a boat anchor.
185, 306, 355188, afr, bbk, cam, comp, ford, heads, holley, intake, mustang, numbers, power, systemax, vs
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
