hey guys new to the 5.0 engine whats the difference between the explore gt-40p heads and gt 40 heads the FRPP sells??? and what would be the best bang for the buck for power increasses on a 91 lx vert with an auto
thanks for ur input
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
mods: JLT cai, flowmaster 40's, coming soon LT's
best et: 13.36 at 105mph and 8.69 @83.26 1/8
Vehicle: 1992 Ford Mustang LX convertible and 2003 Ford Mustang
I agree with gears, I have a 92 lx vert auto(for now) and when put 4.10 gears in it really woke up. As far as GT40 vs GT40P I am on this topic now, the GT40p's are newer and have the spark plugs in a different place, which means in most applications you need different headers. They are also supposed to flow a bit better I believe. As far me I think I'm just going to use whichever ones I can get my hands on and port them. There seems to be many people who run those heads on here so maybe they will chime in to help you more than I could.
they perform better because the spark plug angle is supposed to be more optimal for combustion
gt40ps flow better and create more of a "swirl" in the combustion chamber, i picked up a pair a lot of long tubes work with them you just need 90 boots on some of your spark plugs and it adds extra time changing plugs
__________________
1987 Mustang GT Hatchback stock motor BBK CAI, 255lph fuel pump, BBK Adj fuel pressure reg, msd dist, maximum motorsports caster camber plates, ram hdx clutch, BBK adj clutch cable and firewall adj, 3g alternator, 03-04 cobra replica wheels, strut tower brace, 3.73 gears fresh clutch packs, Gt40ps steeda #18 and explorer intake in the works
any other good cheap mods for extra power or other free mods that could b done. like maf screens or throtle body heater bypass...etc and has anybody had good luck with underdrive pullys??
thanks guys
__________________
Free mods/cheap mods: bump up timing, remove air silencer in fender(if not done already), clean out MAF(a dirty one will really hurt your performance). But first I would install a transmission cooler and a shift kit. No needing adding a lot of mods only to have your AOD break down on you.
__________________
95 Mustang GT
TrickFlow H/C/I + AODE + Vortech SQ@16psi + Tweecer Tuned by Fritz Kloss
New Dyno #'s: 396rwhp/431rwtq(ran out of fuel)
New ET: 7.57@91 (1.84 60ft) http://www.youtube.com/watch?v=el5XYPGj4sM&feature
DD: 95 Mustang GTS- 5 spd; 306ci, Magnaflow X, Summit headers, Pypes Cat-back, K&N, MGW shifter
New ET: 9.7@72(2.34 60ft)
