Installed Air rid bag...Launch as stright as an arrow
Well, with all of the power and the right rear squatting to low, I took care of that problem! I added a air bag with 15 psi, took her out for a test launch and low and hold on, straight as an arrow! The total install only took less the one hour including all of the routing and prep.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
I have one installed. came with my Eibach drag springs
I just came back from Key West, FL and went right to work on it. 1 hour later it was complete. I took it out and with a 15 psi...I must of hit the magic # It launched perfect! You got to love these inexpensive fixes. My right rear would dig in deep before. How do you like yours? What pressure are you at?
You guys are a little slow i see.A lot of g body guys have used those air bags for a while it helps.And the g body rear suspension is pretty close to the mustangs.
I have two bags that way i can raise the car on the street and then when i go to the track i run 0 in the left bag and 15 on the trans brake and 8 on the foot brake
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
