Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-01-2009, 05:38 PM   #1
Mahon
Vehicle: 1984 Ford Mustang
Default bad night... need help
ok so i was cruising my car last night, got up on the interstate, and got on it pretty hard, and so i blew a heater hose, so anti freeze got sprayed everywhere. and then my car dies. i push it off to the side and what not. and sat there for a while and still it wouldnt start. and then my friend towed it about maybe 200 feet. and it started up fine, then we towed it to his to be safe. this morning i replaced the hose and everything, car started but now the starting seems way more rough, maybe i just kicked the started lose a little or something, but when i try to drive it, it seems to try to die on take off and i can get it past 3k rpm. it chugs out and sounds like all the cylinders arent firing. why? my mom's bf thinks my distributor may be wet still or something, i really dunno. any thoughts or ways to diagnose this?
Mahon is offline   Reply With Quote
Old 11-01-2009, 05:49 PM   #2
CBurn
CBurn's Avatar
Vehicle: 1993 Ford mustang GT
well do you have a rubber boot on the distributor? do you mean radiator hose?
__________________
1993 mustang GT 5-speed. New factory headlights, steering wheel, alternator, and MAF. Re-painted window wipers & side mirrors. Completely STOCK motor with 170,000 miles. Flowmaster catbacks FOR ULTIMATE VROOM.
"Mustang GT. Get in, sit down, shut up, and HOLD ON."
CBurn is offline   Reply With Quote
Old 11-01-2009, 05:57 PM   #3
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
what hose blew???
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-01-2009, 10:32 PM   #4
Mahon
no it was a heater hose. it was the one the goes on the manifold. from the heater core. and idk if i have a rubber boot on my distributor, i havent got a chance to look yet. had to work tonight. i'm gonna look tomorrow.
Old 11-01-2009, 10:38 PM   #5
mjr46
mjr46's Avatar
Vehicle: 85 mustang
make sure the salt and pepper shakers back there aren't full of coolant, if so clean them out/ blow the connector out with compressed air and install dialectic grease and make sure distributor cap is clean of all coolant/ moisture
__________________
Old 11-01-2009, 10:41 PM   #6
Mahon
salt and pepper shakers? lol what? and ok i'll do that. does it sound like moisture in the distributor to you too then?
Old 11-01-2009, 11:50 PM   #7
mjr46
mjr46's Avatar
Vehicle: 85 mustang
by the throttle body on the back side, look for the two big white and black connectors......as for dist cap, just pop it off and look
__________________
Old 11-02-2009, 12:59 AM   #8
86blackgt
86blackgt's Avatar
Vehicle: 86 ford mustang
how hot did the car get?
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
86blackgt is offline   Reply With Quote
Old 11-02-2009, 01:04 AM   #9
Mahon
uh... it's carburated lol. so ya... but i'll look for those connectors, and ya i'm gonna look in the dist. and it didnt get hot at all. just blew a hose. and steamed everywhere and died. it was quite gay.
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
