Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-05-2009, 06:59 PM   #11
OnyxCobra
OnyxCobra's Avatar
Vehicle: '95 Mustang Cobra
Send a message via AIM to OnyxCobra
traction-loc is actually Fords term for a limited slip diff, posi being GM's term
__________________
CarDomain - OnyxCobra
OnyxCobra is offline   Reply With Quote
Old 11-06-2009, 01:31 PM   #12
luckythirteen13
luckythirteen13's Avatar
ford racing trac loc. when it dies im going with a spool
__________________
7.25 @ 95.17MPH with a 1.70 60' on street tires and low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 11-06-2009, 01:53 PM   #13
slidenotch
slidenotch's Avatar
Vehicle: 91 Hatch Lx
I've actually saw a auburn diff spin both tires with on in the dirt and one on the pavement. My choice is auburn but they are not rebuildable. But if it does ware out. I think it would be time for a spool or mini spool.
__________________
Stock 5.0. T5. bbk el shorties CAI. 3.73 gears. UD pulleys. E303 cam. Msd Coil.
slidenotch is offline   Reply With Quote
Old 11-07-2009, 05:02 PM   #14
Signal 20
Vehicle: 1993 Ford Mustang LX
ok so while still on the subject of the rear ends I am currently rebuilding mine and cleaning it up. What is the large metal block that is bolted to the underside of the rear end up by pinion yoke? It is held in by 2 bolts and between the rear end housing and the bottom of the metal "block" is some very worn out bushings. I'm guessing it is a weight or possibly to reduce vibration, however my bushings are very worn out and I have not seen replacement bushings out there for it. Is there any reason why I cant go without it?
if you cant figure out what I'm talking about I will take a pic tonight and post it up.
Signal 20 is offline   Reply With Quote
Old 11-08-2009, 11:58 AM   #15
slidenotch
slidenotch's Avatar
Its a vibration block. I forgot the exact name for it. TAKE IT OFF! They are pointless and like to make noises when wore out.
__________________
Old 11-08-2009, 03:34 PM   #16
Signal 20
Quote:
thanks for the advice, mine was very worn out and was not even tight against the housing anymore
Old 11-24-2009, 10:02 AM   #17
Signal 20
I have been doing more research and I'm thinking about just getting a 31spline housing and rebuilding it with the carbon fiber clutch kit. If I go to the bone yard and yank a 31spline housing from a 8.8 truck or suv rear end will that be the same housing that I would get it I baught the ford motorsports one? trying to save all the money I can to be used on other parts
Old 11-24-2009, 10:39 AM   #18
uedlose
1989 Ford Mustang
uedlose's Avatar
Vehicle: 89 mustang
Before I went to a spool I ran a Ford T-Lock. I tried the mini spool before the full spool it broke after the first year don't think I would run one of them.
__________________
New low boost times 11 psi 10.91 @ 128 MPH 1.76 60ft 6.98 1/8 mile. still only a 306 CID yes its been a lot faster.
uedlose is offline   Reply With Quote
body, carrier, fox, rear
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
