well check if they are aluminum or not. if they are grab them for sure. there really rnt good cast iron heads unless u want gt40s. on the side of the head look for 3 vertical bars and a GT on the bottom corner. um grab the ponies if you can afford them. chrome ponies go for a good amount of dough. control arms are easy to install and remove. you just need to bring a jack and jack stands or stuff junk wheels found lying around the yard under the car. once you get the rear wheels off you can yank out the springs and then you can take the whole catback out like that so u wouldnt need to cut n e thing. damn if that was near me i would have the whole car stripped in no time.
and ull need that maf to run the 24# injectors that that guy was running on the car in the yard
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
SVO GT40x Aluminum Heads, FRPP F303 Cam, GT40P Intake, 3.73s, Full Exhaust and Suspension
First thing you should do is sh*tcan that 75mm throttle body. Way too big for a stock motor. Decent price for the intake. Now you need to get the lower sent out to tmoss for some portning.
__________________
2001 Nissan Maxima SE 5sp - Sherwood Green (daily driver)
2005 Ford F-350 PSD Crew Cab - White (tow vehicle and rotary owner)
1993 Ford Mustang LX 5.0 - Vermillion (for smokey Dairy Queen burnouts)
2008 Toyota Camry Hybrid - Barcelona Red (wife's ride...something has to get good milage )
I'm just wondering since it had a 75mm Tb and 24lb/hr injectors. It might have something internally. I would just yank the motor and get what you want.
Is it a t5 or AOD?
__________________
Stock 5.0. T5. bbk el shorties CAI. 3.73 gears. UD pulleys. E303 cam. Msd Coil.
call someone that owns a torch and just cut the damn front end off and cut the cross memeber and motor mounts and take the whole motor
__________________
92lx frpp 5.0 gt40, vortech s-trim 14# Mighty mite m2 c4, Trickflow track heat, 4800 tct stall, 3.73 rear gears, true-trac, moser 31s,Wilwood drag brakes, strange 10-ways on all 4, weld prostars, M/T's & skinneys, Team Z Motorsports front k member kit and coilovers, eibach drag springs dual airbag
best Et-10.96
best mph 123.60 still got some in it. leaving it in the 60'
3145lbs with driver
Winter objective:10point,mini tub, team z rear suspesion, kirkley seats, 29.5x12.5 m/t et streets
