I am doing a stock rebuild of a 92 5.0 to put into my 82 gt. I got the block, heads, and rotating assembly for $100 and am getting the machine work done for $150. My question is, The block came with an aftermarket cam in it and the guy didn't have any numbers on it. Is there any way to identify it and see what im working with? I dont know too much on cam theory or anything like that so I would love it if someone educated me. I know it would probably be best to just use the stock cam or something close. Everything will be stock except a edel. 289 performer intake and 600cfm carb.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
pull the cam out and look on the butt of it and it should tell you what kind it is
__________________
91 mustang 5.0 lx,306 shortblock,E-303 cam,ported and polished E7's,rebuilt stock T-5,bbk E/L shorty headers,with their 2 1/2" o/r H-pipes,70 mm maf,3G alt.,upr adj. upper c/a's 3:73 gears. race weight with driver:3260,only a 100 lbs. more than the 85
85 mustang: parts car for now
Best time 13.7@ 102 mph 2.074 60' on street tires(in the '85)
Best time 14.3@ 96 mph 2.13 60' on street tires(in the '91)
__________________
stock 86 bottom end with 210k, e303 cam, e7 heads with 1.6 rollor rockers, victor 50 intake, 19 lb injectors, kirban adj regulator, 75mm tb, 76 mm air meter, mac cold air, electric fan, stock pressure plate with mcleod disc, 3.73 gears,qa1 kmember w coil overs, stock rear controll arms, and 26x11.50 et streets, 11.56 @ 121 on a 125 shot, 12.65 on motor
new motor gt40p heads,victor 5.0 intake, 236,232 and 565,545lift cammotion cam 150 wet kit11.26 @125, on motor 12.17 @ 112
__________________
__________________
