Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > 5.0L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 11:45 AM   #1
DGilbert
Vehicle: 2010, gt premium v8, coupe
Default ford stopped using 5.0
When did ford stop using 5.0 in mustangs and what was the best stock HP?
DGilbert is offline   Reply With Quote
Old 11-06-2009, 12:00 PM   #2
motorman524
MF Informant
2008 Ford Focus
My Garage
motorman524's Avatar
Vehicle: 1987 Ford Mustang
They stopped using them in 1995 for the Mustang. Not sure on the best output stock. Probably the 95 Cobra, 240hp and 285lbs-feet.
__________________
Winter Project:
TKO 600 (manual conversion)
UPR K Member Kit w/ Coilovers
Steeda Superlite Rear Springs
Caster Camber Plates
Steeda Control Arms
Holley Systemax
motorman524 is offline   Reply With Quote
Old 11-07-2009, 12:38 AM   #3
nitrous_bob
nitrous_bob's Avatar
Vehicle: 1993 notch
yes '95 was last year but after '92 they stopped using forged pistons
i think that the '89 cars ran best, some will argue that an '87/'88 speed density car will run fastest.... it's close
i can say my '89 truly kicked the crap outta my current '93... by a lot too, about 5-6 tenths slower in this car and it sixties better than the '89 so go figure
__________________
'93 calypso notch 6th stang and counting
nitrous oxide is proof there is a GOD and he wants us to be happy
http://www.myspace.com/nitrous_bob
nitrous_bob is offline   Reply With Quote
Old 11-07-2009, 01:07 AM   #4
TrimDrip
TrimDrip's Avatar
Vehicle: 93, ford, mustang lx
supposedly they bought a gm design engine and started putting it in their cars. Don't know if that is true or not.
__________________
Mustang and no job...
TrimDrip is offline   Reply With Quote
Old 11-07-2009, 01:08 AM   #5
motorman524
MF Informant
2008 Ford Focus
My Garage
^ which design? never herd of this before.
__________________
Winter Project:
Steeda Control Arms
Holley Systemax
Old 11-07-2009, 07:41 AM   #6
mjr46
Sheriff/Mr. Ballbreaker
mjr46's Avatar
Vehicle: 85 mustang
I like 89 best
__________________
Quote:
Originally Posted by dudeboy View Post
Be polite and cordial when you talk to them, as pissing off the guys that can help you is seldom a good idea.
mjr46 is offline   Reply With Quote
Old 11-07-2009, 03:54 PM   #7
rdavin622
1995 Ford Mustang
rdavin622's Avatar
Vehicle: 1995 Mustang GT-S
dont quote me on this but I do believe 87-92 GT's were rated at 225 HP and 300 Ft/Lbs of tourqe. The 93 GT was rated at 205 HP not sure about TQ. The 94-95 Gt's were 215HP and 285TQ. I'm not familiar with pre-87 cars so I dont know what they had for hp
rdavin622 is offline   Reply With Quote
Old 11-07-2009, 06:03 PM   #8
baddestmofo
baddestmofo's Avatar
Vehicle: 88mustangGTFO
I found this a while ago:
http://phystutor.tripod.com/stang/engines/50.html
If anyone knows of any misinformation in it, do tell right away!
__________________
This battle station is fully operational
Now all we need is a little energon, and a lot of luck... -OP
baddestmofo is offline   Reply With Quote
Old 11-07-2009, 06:17 PM   #9
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
Quote:
The 1993 5.0 Cobra featured SVO GT-40 heads and intake manifold, better flowing exhaust, 65 mm TB, 24# injectors, 70 mm MAF and a recalibrated EEC-IV computer. Conservatively rated at 235 HP (was actually around 265 FWHP).
BHP... not FWHP
did not have a different exhaust, the heads were NOT SVO... the aluminum counterparts were an SVO production item
Quote:
1993 Cobra -- 235 HP
* Same cast pistons as 5.0 H.O.
* Cast iron GT-40 heads
* Shorter duration, higher lift camshaft
* 1.7:1 ratio roller rocker arms
* Cast aluminum GT-40 style intake
* 65 mm throttle body, 24 lbs-hr injectors, 70mm mass air meter
* Special type exhaust manifolds
* Specially programmed EEC-IV
Valve lift was not due to larger lift at the cam, it was due to the 1.7 rockers. duration and LSA were different, as were valvetrain timing events
same HEADERS as a GT
im kinda saddened that you did not list the 1994-1995 engines
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
50, code, date, ford
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
