voltage too high at tach sender on hei.
11-30-2009, 03:21 PM
hey guys, i have an hei dizzy. the after market tach doesn't reg. it turns on but does nothing with the engine running. i checked the voltage at the tach sender with it running and got a full 12v. i know it should be between 1.5v and 5v. any clue as to why its at 12v?
thx in advance.
will...
12-01-2009, 04:08 PM
12-02-2009, 07:37 AM
Did the tach work before the melt down? Is it still the same dizzy since the meltdown?
12-02-2009, 01:34 PM
not sure if it worked before. guy i got it from said it worked. but never got the motor fired before the meltdown.
thx
12-02-2009, 06:16 PM
do you have another car you could hook it up to to try it?
12-02-2009, 06:48 PM
D.R. THE PATHETIC DORK
what kind of aftermarket tach?? and how are you trying to pick up a tach signal?? neg side of coil is the side used.
12-02-2009, 07:22 PM
no other car that i can test it on. the tach is an auto meter pro comp, the dizzy is an MSD HEI. connecting the tach to the tach output on the HEI.
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
Drastang
09-30-2015 03:48 AM
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
1991 ,
91 ,
feedback ,
ford ,
hei ,
msd ,
mustang ,
output ,
signal ,
tach ,
tachometer ,
turns ,
voltage
