Question about mounting the battery in the trunk
Old 12-16-2009, 01:27 PM
gnx547
gnx547's Avatar
Wait, I just notice your car is a fox body, mine is a 95 gt..Is there a grommet on the same location on the 95?
gnx547 is offline
Old 12-16-2009, 01:35 PM
FivePointOhh
in limbo
FivePointOhh's Avatar
i dunno, go out and look
it might be. i fished it through last time without removing my fender...just the cover itself.
FivePointOhh is offline
Old 04-12-2010, 09:43 PM
gnx547
gnx547's Avatar
I"m in the process of installing the battery in the trunk and how do I connect the positive cable to the original cable? The screw for the eyelet keeps on turning and won't come off. How do I remove the old eyelet and screw so I can attach the new cable to it?
The bolt holding the seat belt bracket, Is this a good ground to use?
gnx547 is offline
Old 04-12-2010, 10:01 PM
minnow81469
minnow81469's Avatar
there is a grommet hole on the passenger side in the fire wall just so you know can run it like a sub all the way except its on the passenger side
minnow81469 is offline
Old 04-16-2010, 01:18 AM
gnx547
gnx547's Avatar
I want to remove the OEM positive cable for a cleaner look, but there is a red wire from the positive battery that goes to the fuse box, can I eliminate that wire? Or does it have to be there?
gnx547 is offline
04stangman
09-17-2015 01:45 PM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: Question about mounting the battery in the trunk
