gt40 smog issue?
Old 01-08-2010, 11:41 AM
9redfox3
9redfox3's Avatar
Default gt40 smog issue?
On the stock E7 heads there is a hole on the back of one of them with a line going from it to the smog pump. I was told this was... something with the word termactor in it.... anyway, the hole is not there on the GT40 heads. It seems necessary for passing emissions. So whats the deal?Do I need worry about this?
9redfox3 is offline
Old 01-08-2010, 01:10 PM
goathead75
goathead75's Avatar
Thermactor port that's for the smog pump. I believe they are there for the GT40 heads, but the GT40p heads do not have them. You should still pass emissions with no problem, but should also delete the smog pump. The only way you'll fail is if they do a visual inspection.
goathead75 is offline
Old 01-08-2010, 04:22 PM
nitrous_bob
nitrous_bob's Avatar
are you sure there isn't just a plug in there.. it'll look like a threaded hole, but it has a slot in it.. you can remove it
most people use the thermactor plugs which are technically "threaded inserts" when they ditch the smog
if you don't have a viz... you'll be fine, it'll still pass a sniffer test w/ no cats and smog pump unless it's pig rich or broken
nitrous_bob is offline
Old 01-08-2010, 05:12 PM
lxman1
lxman1's Avatar
Mine stock wouldn't pass the sniffer test here without cats. Blew 700 without, 029 with.
lxman1 is offline
cr620
10-03-2022 10:18 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Teddi
09-29-2015 12:24 PM
Quick Reply: gt40 smog issue?
