need help deciding on crankshaft and pistons
120k milage is LOW. As long as routine maintanence was done on that engine, all it should need is a quick hone to the cylinders, some new rings and some light emery work to the crank journals.
You could go a little further and have the pistons refurbished at a machine shop, but that's only if you find some slop in the wrist pins or heavy carbon build up in the ring lands.
120k milage is LOW. As long as routine maintanence was done on that engine, all it should need is a quick hone to the cylinders, some new rings and some light emery work to the crank journals. You could go a little further and have the pistons refurbished at a machine shop, but that's only if you find some slop in the wrist pins or heavy carbon build up in the ring lands.
jwog666
12-27-2021 08:09 PM
BeatnikFink
10-01-2015 08:00 PM
