if running a slick and a clutch that will grab, I don't think you will be to happy with a t-5. With tires that will spin a bit off the line, you really don't have to worry about it. Power shifting into third with a lot of torque behind it may still cause some problems though.
I know a guy that busted third with a promotion transmission this last weekend. It was an 8.30 car. It really should have been a 7.0 car but, he went with the wrong cam.
I'm not planning on dragging the car. Its going to be strictly a secondary vehicle/weekend warrior so it wont see any high RPM launches. I'm sure it will see SOME higher RPM shifts though. A WC will hold that right?
This should have been included in your original post.
In the original post we read AFR heads, 10:1, big cam and the key words I took from the original post. " Will it hold it reliably?"
I was going to reply TKO but if you are not going to use the power, shift accordingly and run it on normal tires. A T5 will probably survive.
