Comp 35-320-8 cam? anyone ever run one?
Old 05-05-2010, 11:30 PM
1987notchback
1987notchback's Avatar
Default Comp 35-320-8 cam? anyone ever run one?
hey guys i am looking to install a set of crane 1.7 roller rockers and a explorer intake i am also looking to replace the cam in the meanwhile. i wrot to comp cams and they recomended the 35-320-8 cam anyone ever run this? will i have clearance issues? it has pretty decent lift i am going for good vacuum and drivabilty. what do you guys think?
1987notchback is offline
Old 05-06-2010, 01:34 AM
slowmofive089
slowmofive089's Avatar
hay i had the same plan but when i got the old cam out the cam bearings were washed away. their was 150,000 miles on it. so just be ready for that . now i am getting the bottom end done. how many miles are on it?
slowmofive089 is offline
Old 05-06-2010, 02:00 PM
1987notchback
Default hey
the car has 200k on it the engine has 75k on it but that was according to the previous owner..... that sux about the bearings, i hope mine are ok. i am just trying to fix the mistakes the previous owner made.
Old 05-06-2010, 09:21 PM
Bubba 95SN
Bubba 95SN's Avatar
You are in for a ugly suprise to the wallet. Used cars are sold as is. Ok, here is the nasty truth ...three legged horse traders. How well does a three legged horse run? Life lesson learned.
Bubba 95SN is offline
Old 05-07-2010, 03:07 AM
slowmofive089
yea you in for some suprises i only planed on spending about $500 ( heads ported and cam)...haha yea right!! breaings gone now , so took the bottomend off and good thing cause all the bearings are washed away. mine as well save up and do the whole block. only cost me $125 for .30 over $22 for cam bearings, $65 to grind the crank and about$80 for rings and crank bearings. not as much as you might think . pistons and rods are where the money really bumps up.
Old 05-08-2010, 05:12 AM
1987notchback
I bought the car as a project, this is not my first. it would not be any fun if there was nothing to work on Just seeing if anyone had used this cam.
Old 05-08-2010, 10:19 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I did a custom cam the has over .560 lift and just under 220 duration for good idle and vaccum and rpm shift is at 6200 iirc, and it rocks with a less than desirable h/c/i it ran 12.6 out of the box, the car pulls hard all the way up to shift point props to FTI
mjr46 is offline
Old 05-08-2010, 02:51 PM
1987notchback
hmm. i did not even know who they were til i googled them. sounds like that extra 100 bucks is worth it. thanks
Old 05-08-2010, 09:55 PM
mjr46
mjr46's Avatar
for me it was, I matched all the parts and wasn't looking for a fast ride, just something with a little more zing than stock and I used parts that I got for a real good deal and others I had laying around, for example the edelbrock rpm heads I put on, I got from a friend for 450.00 and they had less than 2k miles on them, he was hard up for cash, so why not for 450.00.., but with the custom cam, once the designer knows the parts you will be using and what your goal is they can set you up with a matched cam to your combo
mjr46 is offline
Old 05-08-2010, 11:05 PM
1987notchback
thats what i am lookin for now a little more than stock. i do not have the money to do a stroker or full on build like i would like to do. i have a gt40 intake from an explorer that i picked up cheap and am lookin for better than stock heads at a reasonable price i have a set of 1.7 crane roller rockers i picked up for next to nothing. what heads would you recomend? i have been watching gt40's on ebay but they are all 300+ for beat to hell heads. i do not want to go to cheap as heads are a lot more of a pain to change and expensive to buy twice. i appreciate any reccommendtions. thanks mike
Quick Reply: Comp 35-320-8 cam? anyone ever run one?
