Question about mark VII rear and heim joints - MustangForums.com
Old 06-25-2010, 10:25 AM   #1
5.flow
5.flow's Avatar
Default Question about mark VII rear and heim joints
hi guys, I just bought a 92' lx that was a 4cyl in its previous life and is now has an efi 5.0 conversion. The previous owner used a rear from a Lincoln mark vII to convert the car to four wheel disc/5 lug. The rear suspension has coil over springs + heim joints. My question is: can I use a different type of lower control arm and keep the coil overs? The heims seem a bit aggressive for a daily driver. My concern is with the rear being from a lincoln, i don't know if stock style lower control arms will be the right length.
5.flow is offline   Reply With Quote
Old 06-25-2010, 10:45 AM   #2
rmodel65
Yukon Cornelius
rmodel65's Avatar
the lincoln=fox should be the same
rmodel65 is offline   Reply With Quote
Old 06-26-2010, 10:08 AM   #3
KNS1
I have the same rear in my car and I am using the Steeda lower control arms without any problems.
KNS1 is offline   Reply With Quote
Switching from 3.89 to 3.00 gears... musnicki Classic Mustang General Discussion 8 09-23-2015 07:11 AM
Best Place To Run Power Wire/Firewall '08 cbird1177711 2005-2014 Mustangs 3 09-02-2015 08:51 PM
HELP A/C Wont blow cold, electrical 2008 cbird1177711 2005-2014 Mustangs 0 09-02-2015 04:12 PM
Labor Day Savings at AmericanMuscle! AMAlexLazarus AmericanMuscle.com 0 09-02-2015 08:59 AM
arms, control, lincoln, lower, mark, pics, rear, suspension, vii
