Rear seat delete results
Old 07-05-2010, 04:33 PM
89GTnoob
89GTnoob's Avatar
Default Rear seat delete results
Currently not mounted to the floor, but it's 3/4" mdf and a tight fit so I don't think I'll have much of a problem. Thanks for all that answered my questions.
89GTnoob is offline
Old 07-05-2010, 06:37 PM
5.0kid
5.0kid's Avatar
looks good
5.0kid is offline
Old 07-05-2010, 07:18 PM
kweb288
kweb288's Avatar
Looks good man! hope my pics/input helped you out!!!
kweb288 is offline
Old 07-05-2010, 07:28 PM
89GTnoob
89GTnoob's Avatar
Sure did, thank you sir. The only problem I have is that I couldn't extend my sides out to the arm rest. I have a space underneath of the front of it that I need to build side peices for to clean it up.
89GTnoob is offline
Old 07-05-2010, 10:18 PM
1987notchback
1987notchback's Avatar
looks real clean man good job!
1987notchback is offline
Old 07-06-2010, 01:09 PM
kweb288
kweb288's Avatar
ya i see that, not sure how you installed the piece, but i found it was easiest if you made a solid piece and installed it from the cabbin (not from the trunk) and you cut the corners to conform to the plastic.
still looks good tho
kweb288 is offline
Old 07-06-2010, 04:00 PM
89GTnoob
89GTnoob's Avatar
I found that it was more than 4' across from armrest to armrest (I think I did anyway), and made a solid peice out of a 4'x8', so I didn't want to worry about making multiple peices. In the bottom left corner I came up a good 2 inches short somehow and had to screw in some wood peices. I stapled it and tried to add some supports to it and it should hold up (knock on wood). I made the process a little too complex and made a rough cardboard cutout, then had a backup plan where I made 1' offset marks on my cutout and had all sort of wacko alignment marks. I didn't exactly botch it though so I'm happy.
89GTnoob is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
wileec
09-11-2015 10:16 AM
Camster
09-10-2015 11:18 AM
09-08-2015 11:50 AM
Quick Reply: Rear seat delete results
