Tearing her down
Tearing her down
Well me and a friend started taking my engine apart and I was thinking what I should do while Im at?? Nothing expensive, but maybe bore and new pistons? If so what sizes? Remember Im green need specifics about everything.
Check the cylinders for excessive wear. Clean the carbon off at the top of the cylinders and check for a ridge left by the top compression ring with your fingernail. If there is no ridge just freshen it up with a good hone and new rings. If you have a noticeable ridge you might consider going 30 over and installing new pistons. If you buy new pistons have the rotating assembly balanced when the block is being bored.
