tremec 3550 crossmember???
Old 08-30-2010, 07:54 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Originally Posted by AdderMk2
fox doesnt need the spacer
that's what I thought....so since it doesn't I guess this is all I need
3 qts of this
http://www.summitracing.com/parts/NAL-12345349/
and 1 of these
http://www.summitracing.com/parts/FMS-M-5059-A
mjr46 is offline
Old 08-30-2010, 08:12 PM
AdderMk2
Banned
AdderMk2's Avatar
the length of the bellhousing/trans combo...
AdderMk2 is offline
Old 08-30-2010, 08:15 PM
ctgreddy
ctgreddy's Avatar
yes and yes. same stuff i put in my trans.
ctgreddy is offline
Old 08-30-2010, 08:17 PM
ctgreddy
ctgreddy's Avatar
so if you run a fox length bellhousing you don't need one then?
ctgreddy is offline
Old 08-30-2010, 08:28 PM
mjr46
mjr46's Avatar
So what are the gear ratios on these tremecs??? is there a way to reference the tag on the tranny?? if so what are the key numbers and where to reference them??? I wanna compare to my t-5
mjr46 is offline
Old 08-30-2010, 08:37 PM
ctgreddy
ctgreddy's Avatar
which 3550 do you have?
figure out if it's a normal tr3550, a tko, or a tkoII.
but they all have a 3.27 1st, 1.98 2nd, 1.34 rd, 1.0 4th, and either a .68 or .83 5th.
the tko II was the only one that came with the .83. I have the normal tko.
ctgreddy is offline
Old 08-30-2010, 08:57 PM
mjr46
mjr46's Avatar
yea I just googled the tranny and it is a normal 3550......numbers were 2600682 which is a regular 3550 and the ratios are nearly the same as the t-5
mjr46 is offline
Old 08-30-2010, 09:36 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
break the welds and install
TrimDrip is offline
Old 08-30-2010, 09:44 PM
mjr46
mjr46's Avatar
don't want to, if I ever use a t-5 in it again as a back up , then I have to do it all again.
mjr46 is offline
Old 08-30-2010, 09:50 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
don't weld it then, mine wasn't...
TrimDrip is offline
Quick Reply: tremec 3550 crossmember???
