Guess my dynojet number please
Or I guess I should say numbers from one pull. I had been having trouble with detonation at low rpm and keeping the car at a steady idle at times. Well, we made one pass and the stankin ac compressor locked up. Melted the brand new belt off the compressor pulley right in front of my eyes. So that problem was found.
Anyways, One pull
17 degrees total timing
12:1 air fuel ratio at the tailpipes
enigne is out of a 99 Mountaineer
cam from 93 HO motor
cobra rockers and intake
70mm throttle body
76mm (if I remember correctly, may be a 77mm) PMAS Maf
Power adder is a 1.5 kb with a 6lb pulley
also an electric fan
reman ac compressor with the actual bearing in the compressor, not the clutches locked up.
Anyways, One pull
70mm throttle body
No. Play my fun game naow!!!
Anyways, something else also was up because his tach deal only showed the pull to 4800. So there was an error on his part or my ignition box or maybe even my new clutch slipped and he thought it was maxed out and let out. I am thinking clutch because it did it to me on the road the other day.
Don't buy the zoom clutch with the kevlar pucks on it if your car makes 327 horsepower at 4800 rpm and 448 lbs. of torque off idle pretty much.
So how much power do you think the car made?
yeah, I was being cheap on the clutch. Problem is, I really don't have the cash to upgrade the clutch or flywheel because the next tune is scheduled to be Thanksgiving week.
This car was suppose to be a street car with a supercharger on it but, it is slowly getting to the point to where it might as well be a track car with all the money, time and just crap that goes wrong with it. Kinda makes me want to put it back original and start a different car.
thanks, lol
I just now computed in my brain that I can't afford to buy another clutch before next Monday so, I guess I will have to reschedule again. He will be pissed too since he was off that week. F my life
Sooo, how bout you all just send me monies
No really, serious time. You ever see how a show enough race car, like a funny car rolls a hundred feet or so after they do a burnout. I was told it was because of the brakes needing to warm up. Once they get warm after the warm up, they work like a champ.
I am pretty sure that it is carbon fiber brakes that do that but, it could be kevlar brakes???
So my serious time question is, is it possible that kevlar needs to warm up? We pulled it straight off the trailer and onto the dyno. Then made a pull.
I have had two wide open throttle pulls before the dyno time. Both times the car had been sitting a while. Once it slipped and the other, I was doing 135 before and still pulling.
So what do you think. Kevlar need warm-up? I know the install was right. The clutch was surfaced 6000 miles ago so I didn't have that done because it did still look smooth. I did use brake cleaner before the install. Also I haven't installed the quadrant yet and have been using the pull clutch pedal to the top to adjust and it seems about right. The clutch starts engaging just about as soon as I let it off the floor. Also new gaskets and seals that show no signs of leaks. So it all seems right.
Oh and here is da clutch. http://www.summitracing.com/parts/ZZZ-HP48-1/
