clutch cable install
Old 12-07-2010, 08:10 PM
anrtman
anrtman's Avatar
Default clutch cable install
i bought a MM clutch cable and firewall adjuster. i cant get this on and working right. i can only get the adjuster on by prying the clutch fork forward. with it on the petal wont even go to the floor to start the car. it only goes half way. with it off the clutch slips and the engagement point is at the top of the petal. anyone know what the problem could be?
anrtman is offline
Old 12-07-2010, 09:19 PM
motorman524
MF Informant
motorman524's Avatar
Are you using a stock quadrant?
motorman524 is offline
Old 12-07-2010, 09:26 PM
anrtman
anrtman's Avatar
i dont think so its aluminum. bought the car with it. this is my cobra btw if that matters
anrtman is offline
Old 12-07-2010, 09:54 PM
Boss_Hotrod
Boss_Hotrod's Avatar
Did you take the black rubber/plastic stock firewall mount off the clutch cable? If not youll most likely have to file some teeth (usually 4) off the white plastic on the cable where so it will fit into the adjuster.
Only other thing I could think of is the cable is on the wrong quadrant hook or the cable is too short. Or worn clutch but thats highly unlikely, you shouldnt have to pry the fork forward if it has the two jam nut on the end.
Boss_Hotrod is offline
Old 12-08-2010, 01:43 PM
anrtman
anrtman's Avatar
new clutch and no jam nuts on the cable. it fits perfectly on the adjuster. i bought it as a kit from american muscle. it seems that it is too long w/ out the adjuster and too short with it. it a single hook quadrant. the cable says 82-04 so dont think its the wrong one. any other ideas?
anrtman is offline
Old 12-08-2010, 02:52 PM
motorman524
MF Informant
Can you post a link to the kit you bought?
Old 12-08-2010, 04:34 PM
anrtman
anrtman's Avatar
i dont see the kit anymore but this is what was in it
http://www.americanmuscle.com/maximu...tch-cable.html
http://www.americanmuscle.com/stficaad.html
anrtman is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: clutch cable install
