biggest cam for stock pistons - MustangForums.com
Old 01-04-2011, 07:51 AM   #1
la.douche
Default biggest cam for stock pistons
if i were to use a stock bottom end on my 5.0 build,
what the largest cam i can use in there without causing a severe ptv issue
i saw in another thread a z303 with stock pistons wont work unless u notch the pistons, what about the x303 cam? a friend has one he is willing to give me along with 1.6 rockers
la.douche is offline   Reply With Quote
Old 01-04-2011, 08:07 AM   #2
Myers407
I am running a F cam with the stock springs and rockers. Could not see much more than that on a stock set up.
Myers407 is offline   Reply With Quote
Old 01-04-2011, 09:15 AM   #3
AdderMk2
Banned
Quote:
theres a brilliant idea... .512" lift cam with springs that are barely good enough for the stock cam.
I bet your car has no sack on the top end
AdderMk2 is offline   Reply With Quote
Old 01-04-2011, 12:31 PM   #4
Mark O'Neal
I love this site....
Its chock full of friendly.......
Mark O'Neal is offline   Reply With Quote
Old 01-04-2011, 12:41 PM   #5
la.douche
well all bs aside, will a x303 with 1.6 have enough ptv clearance or do i need to look into a different cam or pistons
Old 01-04-2011, 12:47 PM   #6
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Quote:
order one, put it in, a see what happens, it might work, it might not...
just dont bitch when it starts to float at 4500...
sn95_331_GT_ yellow is offline   Reply With Quote
Old 01-04-2011, 01:08 PM   #7
la.douche
im not gonna run stock springs or anything like that, i just didnt know if anyone had used the x303 on stock pistons or should i go with dished or cut outs when i do the bottom end...
i'm trying to piece together some of the parts and get things used to save over buying a new TF kit
Old 01-04-2011, 02:09 PM   #8
tohoopty
tohoopty's Avatar
trickflow stage 1 cam works real well
tohoopty is offline   Reply With Quote
Old 01-04-2011, 02:47 PM   #9
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
douche , with any cam install ptv must be checked, so if it clears go with it...I assume you know how to mock up to check for ptv as well as valvetrain geometry??
mjr46 is offline   Reply With Quote
Old 01-04-2011, 02:54 PM   #10
la.douche
my friend will be doing that part, and ill be learning it for the first time that day
hes building building and racing sbf and sbc/bbc for 20+ years
i knew it had to be checked regardless, just wasnt sure if anyone had done the combo without incident already
im waiting to hear back right now about a set of gt40 heads and intake manifold off a 96 exploder to throw in at the same time while i save for the trickflow kit
1968 Mustang Fatback Coyote Restomod poke68 Classic Mustangs (Tech) 21 12-15-2015 07:25 PM
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 03:21 AM
1077hp / 909 ft lbs torque 4V 4.6 motor angeljoelv SVT Forums 0 09-10-2015 10:12 PM
Opinions regarding 2015 Base Mustang GT w/19' wheels & Ford Racing Handling pack? mungodrums Suspension 0 09-07-2015 08:22 PM
New member and just bought my first mustang Luke9222 New Member Area 7 09-04-2015 07:46 AM
46, 50, 50l, 95, biggest, bottom, cam, end, gt, largest, lift, mustang, pistons, stock, x303
