Finally got my oil dip stick out!
Old 01-16-2011, 09:25 PM
19stang88
19stang88's Avatar
Default Finally got my oil dip stick out!
So after a year and half I have been driving without a oil dip stick tube. So oil has been spewing out from the open hole. The oil dip stick broke flush to the block while removing my stock headers and installing aftermarket ones. So finally, it is out!
I removed the headers (I don't think you needed too) then stick the tool I made and pulled hard! And it just ripped out. I tried a paint can opener, pliers, a chisel, and even thought about dropping the oil pan. Hopefully this helps somebody out
19stang88 is offline
Old 01-16-2011, 09:41 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
easy outs are what I have used, = 2 sec and out
mjr46 is offline
Old 01-16-2011, 10:04 PM
19stang88
19stang88's Avatar
I have heard about using that but I didn't want to have metal shavings.
Old 01-17-2011, 12:52 PM
capri debris
capri debris's Avatar
I can't understand why a paint can opener wouldn't work... it's worked fine for me three different times. The only problem I ever had was one that was really stuck and I couldn't get it to hook on, so I took a grinder to the tip of the can opener and re shaped it and pulled it right out. I don't see a difference between the tool you made and a pain can opener. ??? I think you may have given up too soon on the paint can opener idea. At least you got it out, that's the imprtant part, but I think you made this problem harder than it should've been though.
capri debris is offline
Old 01-17-2011, 01:01 PM
TexasTanker19kilo20
Goldilocks
TexasTanker19kilo20's Avatar
Great pic. Maybe when someone googles this problem they will see this and the paint can opener idea, but a Year and a half..WOW. How much oil did you lose a week?
TexasTanker19kilo20 is offline
Old 01-18-2011, 12:35 AM
19stang88
19stang88's Avatar
I've tried the paint can opener many times. I used like 4 and I wouldn't get the thing out! the paint can opener was a great idea and i got it from you but every time i would try to get some pulling force it would slip and not grab. I finally said screw it, so i removed the headers to have more working space and pulled the damn thing out. I think the reason why I couldn't remove the broken oil dip stick tube was because I probably lodged it further in trying to replace the dip stick tube and not now there was a part broken into the block. I might have taken more time, but it is a lot better than dropping the oil pan.
Hopefully, stuff like this happens all the time. Yeah I know, oil just poured out like crazy, i probably lost 2 quarts a month. I just filled it every time my check oil light came on. Not very healthy for my engine, but she is still running like a champ.
BeatnikFink
10-01-2015 08:00 PM
wraith777
09-28-2015 10:49 AM
MacSerio
09-27-2015 01:05 PM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Finally got my oil dip stick out!
