supercharged 331 on a stock block?
#31
#32
if you want 400 na power a good set of heads id suggest an afr 185 or 205 or a tfs high ports, idk if they can pass a smog test i would imagine with out a power adder 400 n/a hp in cali would be a hard one to get. the kit looks decent id propably get a bit more compression like 11:1 you dont mind running 93? do you?
#33
wouldnt mind running 93 if it was available but the highest octane we got out here is 91...
i was out in ohio earlier this year and noticed all the gas stations offered 92 or 93 i was like wtf???
#34
Go ahead and run a stock block. I'm a 331(stock block) with 15psi+ of boost. Difference is, I don't beat on it that much. Plus it's an auto and I do a lot of 2nd gear roll-ons. Make sure you get a main girdle put on to help strengthen the block a bit. As for losing low end torque, it would all depend on the H/C/I combo thrown on as 5.0kid said. I reused my TFS stuff. Torque down low is slightly stronger, but the mid-range pull is much stronger.
Galactic
04-29-2019 02:56 PM
09-08-2015 05:21 PM
09-03-2015 07:14 PM
