Aftermarket Iron Heads
Old 02-07-2011, 05:47 PM
EffunFiddy
EffunFiddy's Avatar
Default Aftermarket Iron Heads
Are there any aftermarket iron heads that DON'T have stud mount rockers? I know alot of people like them for better roller rockers, but I'd prefer to stay away from them if possible. I've checked out Dart and World and even RHS but can't find anything with pedestal mounts. Any help would be greatly appreciated. Thanks!
EffunFiddy is offline
Old 02-08-2011, 04:30 AM
ttocs
ttocs's Avatar
if you are swapping out heads, why go iron?
ttocs is offline
Old 02-08-2011, 05:58 AM
AdderMk2
Banned
AdderMk2's Avatar
why stay away from studs? Its a much more stable platform then pedestal mount.
AdderMk2 is offline
Old 02-08-2011, 10:42 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
sigh....
sn95_331_GT_ yellow is offline
Old 02-08-2011, 09:06 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
There is a reason why aftermarket heads are stud mount.......
If you don't want what you have find some GT40's....
projectresto83 is offline
Old 02-09-2011, 12:57 AM
tinman
tinman's Avatar
Check out the Roush heads.
I think that you can have pedistal mounts if you want and they are iron.
BTW, whats wrong with stud mounts?
tinman is offline
Old 02-09-2011, 10:23 PM
EffunFiddy
EffunFiddy's Avatar
Hey thanks for the quick reply, the reason I was curious about stud mounts is because my understanding was that stud mount rockers need frequent adjusting. Not bashing stud mounts or anyting, I'm just new to the concept and don't know too much about them or properly adjusting them. I already have GT40s but was looking for something that produced a bit more power and was hoping to stay with iron heads to save money. Stud mounts aren't a big deal after all? Like I said, I'm new to these. Thanks again for the help everyone.
Old 02-10-2011, 02:08 AM
67mustang302
67mustang302's Avatar
Stud mounts shouldn't need constant adjusting unless something wasn't set right(locks are too loose) or something is wearing.
That said, people underestimate pedestal mounts. They're actually a very stable platform and flex less than a lot of studs do(except for large studs made with high end steels). But the smaller capscrew can fail under heavy spring loads, the smaller shaft diameter means less total tensile load capability. So they're not a good idea in something using high spring pressures.
And just as an FYI, GM's LS7 engine uses pedestal mount from the factory with an 8mm capscrew(which is the metric equivalent of 5/16" that ford pedestals use).....on an engine with a 7,000rpm redline and a huge 1.8 rocker ratio and large valves(though they are titanium which helps with valve mass).
Studs are generally preferred because they're more easily adjusted.
67mustang302 is offline
Old 02-10-2011, 02:43 AM
19stang88
19stang88's Avatar
i'll be happy to purchase your heads when your done with them
19stang88 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
Drastang
09-30-2015 03:48 AM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
Quick Reply: Aftermarket Iron Heads
