Injectors
Old 03-31-2011, 07:51 PM
koicle
koicle's Avatar
Default Injectors
I have a stock 87 I purchased a cold air intake and 70mm sensor,throttle body and EGR plate I was looking for injectors and was wondering if anyone could tell me what I need and where to find them. Thanks
koicle is offline
Old 03-31-2011, 09:58 PM
pete88gt
pete88gt's Avatar
Have you converted to mass air? You said you picked up a 70mm sensor...What size injectors is that sensor calibrated for? For a completely stock 302 ie no cam, intake, or heads, your throttle body is really too big. If you want to use that 70mm, keep in mind there are forced induction guys running 65mm tbs, I would upgrade to at least an explorer or cobra intake and then go to 24lb injectors, available on any number of mustang parts websites, ie American Muscle, 5.0 Resto, ...
pete88gt is offline
Old 04-01-2011, 06:54 PM
koicle
koicle's Avatar
Thanks Pete my plan is 347 and alumimum heads
koicle is offline
Old 04-02-2011, 12:10 PM
Autotech
Autotech's Avatar
I run 30lb injectors and a 70 mm on my 347, and ran 24lb when it was stock 302.. I do spray 300hp in the 347 and seems to work well. If you are gonna turbo it, you will want even bigger injectors. But like pete88gt said, you will need injectors that match you MAF Sensor.
Autotech is offline
Old 04-02-2011, 12:49 PM
stdyhand
stdyhand's Avatar
Maybe I just don't understand something, but why would anyone run bigger injectors and a larger TB/EGR spacer and mass air if they haven't already built the 347 short block?
Do you really gain anything to justify going larger while still using a stock 302? I mean if this is for more performance before building the short block wouldn't the heads be a better choice? Maybe even a mild cam would give better performance than simply those minor things?
stdyhand is offline
Old 04-02-2011, 02:26 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
There is no reason to upgrade your injectors with stock heads still on the motor.
projectresto83 is offline
Old 04-02-2011, 03:03 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
unless you supercharge/turbo it
mjr46 is offline
Old 04-02-2011, 03:10 PM
projectresto83
M.A.D. Motorsports
Lol ok, N/A there is no reason.....
Old 04-04-2011, 04:19 PM
koicle
koicle's Avatar
Thanks guys for all the info just wanted to let you know this is my first go at a street car. I come from a stock car back ground race stock cars for 10 years. I am trying to get as much info as possible so I can do the build right the first time.
koicle is offline
GimpyHSHS
19
12-19-2023 01:12 PM
4cylinderplus2
10-09-2020 07:45 PM
Dathan
10-05-2015 05:52 AM
MacSerio
09-27-2015 01:05 PM
mltdwn12
09-23-2015 08:54 AM
Quick Reply: Injectors
