1990 GT Turbo Install
Hows it going fellas, Just thought I would see if anyone has done a turbo install using the ebay turbo GT45 Y2004K, I know its not the best turbo around but I am trying to build a low budget stang for now. I have a complete stock block, My plans is to keep it arround 400-500hp, I have 3:73 gears that I plan on installing, with a TCI streetfighter valve body, I have worked GT40 heads, Xe270hr-14 cam, Typhoon intake. So any info anyone has on installing this type of turbo or a similar setup. Injector size, flange, downpipe size, wastegate, blow off valve, turbo location, custom tune, or any other custom fabrication that needs to be done. Thanks guys
+1 with on3performance... I went 11.78 last year with stock heads and bottom end with a b303 cam and a lot of supporting mods. I switched to a pony down stage 3 this year though.
why not just spend a few more $$$ and get a Master Power t70 more then enough turbo to last you for a few years and are very reliable and priced right. I think that is one of the upgrades with the on3 kit. Are you trying to make your own kit or are you buying one? I would look into BG turbos and Pony down stuff also and look around on some of the used stuff turbo kits are showing big time on the used side.
Luke9222
10-22-2015 11:55 PM
