Desktop Dyno 2003
Desktop Dyno 2003
I used it with all my flow numbers and all the other engine specs. 348hp @ 5500 rpm ,388trq @4000 rpm. Dont know how close it really is. My build is a 87 gt w/331 stroker, Eagle 3.25 cast steaal crank, Eagle 5.4 SIR I beam rods, KB FHR 4 valve relief ftp, tfs 2 cam, gt40x heads, wieand stealth intake, 750 cfm holley. C4 trans w/ shift kit, ptc 3200 stall, 3.73 gears
Yea I know @ fly wheel.Not to happy with the fly wheel hp. torque is nice though. Yes thats with compression ratio and my head flow numbers. Will have everything put back together soon and back in the car. Picking my 2 blocks up from machine shop today
I'd use the cam @.050 off base circle.
Those programs are all 'emptying/filling' type things so anytime you put more of several different things in it, they will show more HP.
I'd also figure about 20% loss if you have a manual trans and about 22% if you have an automatic.........
junior04
09-28-2015 10:53 AM
