afr165 for 306 with blower (can i keep stock cam?)
I have a 306 rebuilt motor, stock heads, stock cam, gt40 intake, stock injectors with FMU, flowmasters, and Vortech V3 8-10lb boost.
I want to upgrade to...
42lb injectors
75mm PMAS mass air
AFR 165cc heads
Holly systemax intake?
CAM?
What would happen if I kept the stock cam? Because I have never did a cam swap, and i seen some dynos with the stock cam and afr165's and blower, and it was in the mid 400's.. ?
42lb injectors
75mm PMAS mass air
AFR 165cc heads
CAM?
If I got
afr165cc heads
42lb inejctors
70mm TB
75mm MAF
STOCK cam
GT40 intake (TEMPORARY til i get more funds)
Vortech v3 with 10lbs boost
About what would this afr165, gt40 head, and stock cam with 10lbs yield in HP numbers to the wheels with a manual? I want to keep the cam stock for this build possibly. And temporary I am gonna keep the gt40 intake. Will these heads bolt on with no problems? and should I use 1.7 RR's to get more cam lift?
afr165cc heads
42lb inejctors
70mm TB
75mm MAF
STOCK cam
