94 Cobra 347 build
Old 05-16-2011, 09:01 PM
cobrakid94
cobrakid94's Avatar
Default 94 Cobra 347 build
Hello Stangers! I'm building a 347 with a cast Scat crank and KB Hyper flat top pistons. I will be using it for 85% street, 15% track. The heads I'm using are aluminum Ford Racing X306 with about .030" milled off. I plan to lightly port them (bowl and exhaust) and use Comp Cams XE 282HR. Here comes the real question: what other upgrades should I be looking at? There is alot of info regarding GT bottlenecks, but the Cobra has lots of factory upgrades: Intake, MAF, Throttle body, 24#injectors. Are these enough to support a 347?
My other installed parts are MAC equal length shorty headers, Bassani catted X pipe, 2 chamber Flows, and 3.73 gears. Thank You.
cobrakid94 is offline
Old 05-16-2011, 09:43 PM
Venomantidote95
Venomantidote95's Avatar
I`d go with atleast 30`s, a 75mm tb and the intake is iffy!
I`d go with a bigger primary headers than 1 5/8, it will be a peppy combo with just about any decent parts!
I used the scat crank and rods with KB pistons! it has been satisfactory so far!
and a clutch upgrade will be a plus!
Venomantidote95 is offline
Old 05-16-2011, 11:35 PM
tinman
tinman's Avatar
IMO, you need 1 3/4" longtubes for that combo.
Also, you'll need to relieve the block atb the bottom of the cylinders.
I forgot where I got it but there is a tool sold by a company off E-Bay that works great......
tinman is offline
Old 05-16-2011, 11:45 PM
AdderMk2
Banned
AdderMk2's Avatar
You shouldnt use any of the factory cobra parts on your 347. Most of your "upgrades" were good for a 302... not a 347
AdderMk2 is offline
Old 05-17-2011, 09:04 AM
cobrakid94
cobrakid94's Avatar
What are your thoughts on the intake? Port it or somthing bigger? I'm running a t5 trans.
Old 05-17-2011, 09:28 AM
AdderMk2
Banned
AdderMk2's Avatar
something MUCH bigger
... but I'm alittle biased
AdderMk2 is offline
Old 05-17-2011, 09:47 AM
cobrakid94
cobrakid94's Avatar
I'd say!
Old 05-17-2011, 12:58 PM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Originally Posted by AdderMk2
<33333333333
sn95_331_GT_ yellow is offline
11-10-2015 11:39 AM
svfetter
10-05-2015 11:39 AM
88 orangepeel notch
10-05-2015 09:03 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Brett Ludlow
09-23-2015 06:59 AM
Quick Reply: 94 Cobra 347 build
