Shift light question
Old 06-06-2011, 01:23 PM
g3mustang
g3mustang's Avatar
Default Shift light question
In another thread i think we came to some conclusion that my factory tach might be a couple hundred rpm higher then it really is. I really dont like the look of the big tachs and i cant afford a florida 5.0 cluster. So my thinking was, What about just a shift light? But does my factory rev limiter stop me from doing this. if my tach is indeed couple rpm higher then it really is and i set the shift light at 5800 rpms wont the rev limtier take over b/c of the stock tach reading above 6300 rpm
g3mustang is offline
Old 06-06-2011, 02:21 PM
g3mustang
g3mustang's Avatar
i guess what im asking is does the factory rev limiter go off what the tach is showing, or off a different signal
Old 06-06-2011, 03:27 PM
AdderMk2
Banned
AdderMk2's Avatar
factory rev is driven by the same signal as the tach.
get a stand alone shift light
AdderMk2 is offline
Old 06-06-2011, 03:45 PM
g3mustang
g3mustang's Avatar
i understand by getting a stand alone shift light but when i put the shift light to 5500 rpm and what if my tach is off and showing 6300 rpm then im going to hit rev limiter before i really am. im sorry if this is confusing im trying the best i can to make sense lol
Old 06-06-2011, 06:47 PM
g3mustang
g3mustang's Avatar
Try to explain better lol
If my tach reads 500 more rpm then it really is and I set timing light at 5800 then that would mean my factory tach would read 6300 rpm which is past rev limiter
Spat shifting point is the car going to bounce off rev limiter??
Old 06-06-2011, 09:35 PM
AdderMk2
Banned
AdderMk2's Avatar
its the tach itself thats ****ed up, not the electrical system
stop overthinking things
AdderMk2 is offline
Old 06-06-2011, 09:49 PM
g3mustang
g3mustang's Avatar
Lol sorry buddy I just want to try to make things ok
Old 06-07-2011, 12:26 AM
AdderMk2
Banned
AdderMk2's Avatar
It's ok... just don't give the car too much credit. It's not nearly as complicated as some people think it is.
The ECM reads the signals coming from the distributor (PIP). It has a direct link. The factory rev limiter is triggered by the ECM, not the tach.
The tachometer is a piece of what can be referred to as I/O device. The unit is driven by reading pulses, and converting them into the rotation of the needle. If the calibration is off even slightly... the tach will read wrong. Whereas the ECM is only counting pulses, not converting them into a different output.
Think of it like the coolant temp gauge. it says "normal" because its not a finely calibrated piece. its just there to get you in the ballpark.
AdderMk2 is offline
Old 06-07-2011, 07:15 AM
g3mustang
g3mustang's Avatar
Thank you so much for that description.
Old 06-10-2011, 12:29 PM
nitrous_bob
nitrous_bob's Avatar
if you have the stock cam.... even 5500 is way too high so it's not an issue.
i consider myself a pretty good driver, and use a 5200 chip
by the time you react and complete the shift, you'll be around 5500 which is perfect. if you start the shift at 5500 you'll probably kiss the limiter once in a while.
i like msd over the others, dont get the cheap one with the dial.... plugin chip is way better imo
nitrous_bob is offline
Quick Reply: Shift light question
