My Notch Build
Old 09-04-2011, 09:35 PM
  #121
stangoutlaw
stangoutlaw's Avatar
very nice
stangoutlaw is offline
Old 10-27-2011, 09:12 PM
  #122
oatburner99
oatburner99's Avatar
So here's a little update (sorry been working alot and have no life)
Just a quick picture of the car lowered again, better than the sucky phone pictures.
Main news, I picked up 1 other polished cobra wheel (already had 1 spare) so I can mount some Drag radials on them, and not tear up my nitto's when I go to the track. Maybe this will get me to the track more often too lol...
Picked these up as well, although now that I have my other cobra wheel, these will be up for sale shortly:
car needs some love, I picked up the door to body weatherstripping kits from LRS last weekend, need to get those changed out, before it starts raining. Thats about it....I'll post up more when I get it
oatburner99 is offline
Old 10-28-2011, 08:00 AM
  #123
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
I don't know what your gonna do without me there to kick you in the *** to get stuff done man!
Keep up the good work and you know if you need something just call! I have access to alot of little BS up here and might be able to find other deals on stuff your looking for.
projectresto83 is offline
Old 11-12-2011, 08:21 PM
  #124
oatburner99
Picked these up w/hpipe and arp head bolts, gasket's for a price that you all would never believe.
Old 11-13-2011, 10:19 PM
  #125
motorman524
MF Informant
motorman524's Avatar
What brands/where'd you get them?
motorman524 is offline
Old 11-13-2011, 11:05 PM
  #126
oatburner99
they are hedman lt's and a hedman o/r hpipe. picked them up off another forum for a ridiculously cheap price.
Old 12-12-2011, 06:14 AM
  #127
oatburner99
Picked these up for a ridiculously cheap price:
Old 12-16-2011, 07:16 PM
  #128
oatburner99
Little update,
So I started to notice that the car was running a little bit warmer than normal. Found out my water pump was seeping out of the weep hole. In my garage the floor has an epoxy coating on it, which makes leaks really noticeable. That is if you don't have carpet down underneath your car (like I did) and didn't notice it leaking.
Well it got to the point where I would fill it up in the morning before work, drive to work (8miles) drive home and the radiator would be almost empty.
So I picked up a new Ford Racing water pump, new thermostat, new gasket's and ARP's waterpump bolt/stud kit from LRS. Luckily for me (with the help of a knowledgeable friend, not one bolt busted off. Had 2 that were really questionable. Like as your trying to loosen the bolt, it kind of has that "dead" feeling to it, and you start thinking "oh ****, please don't break....please don't break." Well the praying worked, no broken bolts. Found that it was the original water pump that came on the car. 21 years old. Not bad Anyway it finally let go between the shims and the timing cover gasket. Here's a couple of pics:
Just a lil leak:
Out with the old, prepped and ready for the new one:
FAIL:
USED plain and simple (147,000 mile water pump)
Old and new:
Buddies water pump bolt:
All Done!
ARP studs/Bolts and new bypass hoses
Coming up next is this:
Old 12-30-2011, 06:12 AM
  #129
oatburner99
Noticed this:
BBK longtubes 2.5 on the ball and socket are actually 2.25.
Then the ports on the flange have big welds inside. Plan is to smooth them out:
Tools of destruction, diamond cut rotary bits
Old 12-30-2011, 07:40 AM
  #130
Tony71502
Tony71502's Avatar
I'm surprised that FORD doesn't know what galvanic corrosion is. Aluminum bolts in an iron block...
Tony71502 is offline
Quick Reply: My Notch Build
