Suspension mods
Old 06-22-2011, 04:23 PM
Super88
Super88's Avatar
Default Suspension mods
I need some opinions. The suspension on my 1988 LX is stock. I would like to put 10" rims on back when i get a new set. I know that in order to do that, i need to remove the quad shocks. I also know that it can cause punishing wheel hop. but if i do some mods first will it be ok?
Here is what i had in mind before the rims and tires:
-Eibach lowering springs (1.25" drop)
-BBk upper & lower control arms
-KYB gas-a-just shocks/struts
-Steeda rear sway bar with adjustable end links
-Full polyurethane bushing kit
Will i be safe from wheel hop with this set up? If not, what do i need to do?
Super88 is offline
Old 06-22-2011, 04:38 PM
nitrous_bob
nitrous_bob's Avatar
well if you hook...you'll have no hop. spinning tires can still hop a bit but a cheater slick alone will fix it.
yes your mods would do wonders, i like hpm mega bite jrs for control arms... all i'll ever use
uppers are unneeded but if you got the loot just do it while your in there.
i had an '88 notch for about 6 months....the previous owner dropped it an inch, full poly kit from energy suspension and kyb non adjustable at all 4 corners.
it handled like a vette, i was impressed... the rest was stock too
nitrous_bob is offline
Old 06-22-2011, 04:45 PM
Super88
Super88's Avatar
I looked into the Mega bites because someone else mentioned them. The thing is, this is going to be a street car. I might take it to the track once or twice when i have all the mods done just to see what it can do, so i decided to go with BBK because of price.
Super88 is offline
Old 06-22-2011, 04:51 PM
nitrous_bob
find a used set of mega bites... there cant be much diff in price between 2 new though...it's been a while.... but mega bites are great on the street. dont think they are drag race only
Old 06-22-2011, 05:27 PM
lxman1
lxman1's Avatar
I would be concerned about the 10" wheel and lowering the car unless you are going to run a very short tire. People I know who run 10' wheels have had to roll up the lip on the fenderwell for clearance. I run an 8" wheel with 5.5" backspacing. I run 265/50R15 tired with no quad shock. I run the stock swaybar with a cheap set of Latemodel restoration house brand upper and lower control arms. It doesn't wheelhop.
lxman1 is offline
Old 06-22-2011, 05:37 PM
Super88
Super88's Avatar
I have heard that as well. I dont mind doing that for clearance, I just love the staggered wheel look on the fox
Super88 is offline
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: Suspension mods
