Look at this ugliness! All to change my battery tray...
Old 06-28-2011, 07:40 PM
89LX5pointO
89LX5pointO's Avatar
Default Look at this ugliness! All to change my battery tray...
Bought a new battery tray and hold down kit and am gonna freshen up underneath it. Well still in the process, but a lot more work needed than I imagined...a lot of surface rust, so started sanding it down and am gonna buy a wire brush to make easier work of it. Then I'll wipe it down/clean it, primer it and repaint it the same Red as my car. Not gonna do the whole shock tower brace, but up to where the coil mounts. I'll have the engine bay smoothed and painted when the car gets paint in a few years. Luckily it's only surface rust, but still what a PITA! Any suggestions to make it easier, I'd love to hear!
The old battery tray:
Under the old battery tray:
Wiped down a bit:
And started sanding it down this afternoon:
89LX5pointO is offline
Old 06-28-2011, 08:39 PM
Bobert
Bobert's Avatar
yea that is pretty bad, now im curious to see what mine looks like. especially on the strut tower
Bobert is offline
Old 06-28-2011, 09:14 PM
89LX5pointO
Yeah pretty ugly huh!? It's weird, there's zero rust anywhere else in my engine bay, and none on the strut tower by the battery tray, just by the battery location itself. I almost think battery acid leaked or splashed a bit at some point and did it. Ah well, only surface...gonna buy some rust spray remover and nip in in the tail. Guess the rust remover spray makes quick work of it...
Old 06-28-2011, 09:35 PM
capri debris
capri debris's Avatar
The best thing to use on that is POR15 or Chassis Saver. You've got it clean enough in the last pic... it's designed to be brushed on over light rust rather than clean bare steel. (read the label) It will stop the rust in it's tracks and it will never come back... and any new battery acid will not abe able to hurt it. Just apply the POR15, prime and paint... done.
capri debris is offline
Old 06-29-2011, 09:42 PM
89LX5pointO
Awesome, thannks for the info! Actually did end up buying some POR15, but the rust remover product. That took care of it for the most part, but figured I'd use some rust block anyways before the primer and paint so bought some Duplicolor Rust Off I believe it's called (similar to the POR stuff, but found it close at the auto parts store next to where I live). Did 3 coats of it, so gotta wait 24 hours and hope to primer and paint tomorrow.
Old 06-30-2011, 05:44 PM
DJ19895.0
DJ19895.0's Avatar
The same thing happened to me... I decided it was time to paint the engine bay and then I re-located the battery to the trunk. Cleaned up the wires in the process too. Now I can be proud of the under-hood haha
DJ19895.0 is offline
Old 06-30-2011, 10:56 PM
Dj_Seph
Dj_Seph's Avatar
Man. I've had the engine out of my car three times. Makes me wish at the time that I took the time to do that and paint my engine bay. Sadly now the cars my only daily.
Dj_Seph is offline
Old 07-02-2011, 11:52 PM
89LX5pointO
Adding a whole new post for some different before/after pics...check it out!
SteelerNation82
09-16-2015 07:11 AM
wilsonro
4 Cylinder NA and Turbo
09-11-2015 07:13 AM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
Art161
09-09-2015 10:33 AM
Mobiusone stang
09-07-2015 08:46 PM
Quick Reply: Look at this ugliness! All to change my battery tray...
